Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
B100 effect on rubber fuel lines?
Old Sep 5, 2006 | 10:48 AM
yarddog's Avatar
We've almost got our plant up and working. All we need is a source for WVO.
Anyway, I thought I read somewhere that B100 can dissolve rubber fuel line. I just replaced all the stock lines with 3/8"s rubber from tank to VP. The lines are all high quality diesel rated. I need to confirm if this is true or not. If it is I'll have to bend up some hard line and redo everything I just did
Old Sep 5, 2006 | 11:07 AM
infidel's Avatar
Almost 100% of engines manufactured after 1994 have components compatible with bio. Any diesel rated hose likewise will be compatible.
Old Sep 5, 2006 | 01:36 PM
yarddog's Avatar
Good news, thanks!
Old Sep 6, 2006 | 01:35 PM
Lightman's Avatar
While I respect infidel's experience with bio, I used diesel rated fuel hose from the auto parts store in a VW diesel that I ran b100 for 35k straight in.. the hoses swelled and eventually were toast.. Most that run b100 often use Viton or some other synthetic hose.
Old Sep 6, 2006 | 03:31 PM
CSAGrey1's Avatar
Agreed - 94' and newer should be OK. If you replace ony lines you will want to make sure the lines are Viton as well as Viton for any o-rings or gaskets you plan to replace.
Old Sep 7, 2006 | 10:10 PM
yarddog's Avatar
I hope the seals in the VP are viton.
Old Sep 8, 2006 | 01:36 PM
XLR8R's Avatar
Yes - I've been wondering the same thing for an IP cooling prototype we're developing... does anyone know if the internal seals are butyl, nitrile, viton or what?
Old Sep 8, 2006 | 01:44 PM
CSAGrey1's Avatar
NOt sure but as stated before it seems to be the common consensus that rigs made after 94 are OK. I would assume this means our VP44 rigs. Maybe someone ought to put a call in to Bosch and see.
Old Sep 8, 2006 | 01:48 PM
XLR8R's Avatar
Yeah - someone around here ought to have a Bosch tech bulletin handy.
mullishacrew
Mar 14, 2011 09:13 PM
RoadDiesel
16
Jun 21, 2010 09:41 AM
ImpulseHydro
Oct 5, 2007 07:04 PM
Jeremy Cusick
15
May 10, 2004 01:39 PM
torq
Jul 28, 2003 03:30 PM
