Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
View Poll Results: 2-Cycle Oil in the Fuel Tank?
Yes
87
77.68%
No
9.82%
Still not sure...
14
12.50%
Voters: 112. You may not vote on this poll
Old Jul 25, 2009 | 08:07 PM
Jeff5886's Avatar
Ok everyone this is it!
We have all read the countless 2-cycle oil posts, threads, write ups etc. Lets settle this once and for all. All of the information has been put out on the table and its all been digested. To keep the old research in the past and bring what people now know to light......
Should we run 2-Cycle Oil in out trucks Yea or Nay and Why....
Old Jul 25, 2009 | 08:45 PM
old 300's Avatar
Well I'm not sure about long term use and it helping, but I will say that my truck sure runs quieter and seems to be freer. Mybe its just that I think its better so it is but I sure notice it when its not in the fuel. Been using it for a couple years now and plan on keepin' on.
Old Jul 25, 2009 | 08:48 PM
forwardho's Avatar
YES , I use 16 oz to ever 40 gal of fuel. Truck has run good for the past 5 years. I also am using the orginal lift pump.
Old Jul 26, 2009 | 01:56 AM
JJPage's Avatar
This will never settle this debate once & for all.
I have been running Wal-Mart SuperTech, 16oz at every fill up, usually between 1/2 & 1/4 tank for almost 3 years. It quiets my injector rattle, thats the only apparent result thats noticable.
I sent my injectors to Formula 1, through Rip at Source Automotive, Rip relayed to me, that my injectors, these are his words, "were cream puffs".
Translation = Virgins/New/Solid, 2 CYCLE OIL has not hurt them.
Old Jul 26, 2009 | 02:37 AM
Zeus1987's Avatar
well since my truck is not designed to run off the ultra low sulfur stuff i always add some 2 stroke every other tank, It also helped smooth out my idle.
Old Jul 26, 2009 | 06:22 AM
Depends. I think on the VE and VP44 pumped trucks it a a good idea. The P-pump would probably be just as happy pumping gasoline or paint thinner as diesel fuel. The commonrail trucks probably don't need it either.
Old Jul 26, 2009 | 06:55 AM
ofcmarc's Avatar
I run it in every tank. Then again I run 8 months or so every year on #1 as well.
Old Jul 26, 2009 | 08:45 AM
Shovelhead's Avatar
Administrator / Scooter Bum
16oz nearly every fill up.
Quiets the 'rattle' significantly.
As for added lubricity equaling extended longevity of the VP or Lift pumps, hard to say.
I installed a Glacier Diesel Walbro system to eliminate the junque stock pump, and I have replaced two HR-VP44 Injection Pumps that only lasted 1 1/2 years each with a Blue Chip pump.
Old Jul 26, 2009 | 09:50 AM
Jeff5886's Avatar
What ratio is everyone using?
I've always heard the best is 128:1
Old Jul 26, 2009 | 12:26 PM
GasganoFJ60's Avatar
1oz per gallon is a good rule of thumb. Thats what it is for my truck anyhow.
Old Jul 26, 2009 | 02:07 PM
Jeff5886's Avatar
Just started using it today!
Old Jul 26, 2009 | 05:52 PM
jcarrillo's Avatar
I tried it last week. A couple of interesting things happened. I recently installed a lift pump from an 8.3L and it was starting to take pressure dives. It would go up to 17psi and down to 4 or 5psi. Right when I was going to tap my new pump or take it apart to see what was messing with the pressure regulator, I read one of the posts on 2cycle oil. I went to Orielly to get some Valvoline and all they had that looked any good was Lucas. I got a quart and threw it in the FULL tank. It did get quieter but it seemed to get sluggish. The interesting thing though is the fuel pressure came back up after a few minutes and stayed up. Due to the sluggishness I think I will try Marvel Mystery Oil next.
Old Jul 26, 2009 | 08:36 PM
rockcrawler304's Avatar
I use 16 oz about every other fill up depending on my driving.
Old Jul 26, 2009 | 08:51 PM
J.Suplanski's Avatar
Additives
1-2 quarts of ATS trans fluid every tank full! Last 14 years!
Old Jul 27, 2009 | 03:26 AM
89dieselkong's Avatar
I lost 2 LP after I started using it. One was a Walbro after 2 yrs and 25,000 miles, one was an Airdog after 500 miles! Not sure if it was cuased by 2-stroke or not, but that is the common denominator for me, so I will not use it anymore. Power Service it is!!
