Engine stand for a CTD?
I need an engine stand for my 12 valve, Bobcat bought one from harbor freight or something and did not recommend that I buy one. Does anyone know where I can buy one?
I'm told a 4-legger from your favorite hot rod parts house will do. I got one from Summit, but I haven't hung my engine on it yet. Scott at MassDiesel told me that's all he uses, so I'm going to give it a try.
Make sure you use all gr 8 bolts and nuts. I've had an all steel blown 426 with 14-71 blower and injector on a 4 leg stand and it is wiggly to say the least. Add another couple hundred pounds and it must be real shaky. The shop I worked at finally built our own out of 3" x 4" 1/4 wall tube and 1 inch thick mount plate with larger wheels.
The stand that Hillbilly posted is by far the best , you can hang a C15 cat off of one of those , crank the handle and roll it up on it's end , or right upside down,
these are good too, slightly less functional though:
This might be overkill, but it would work.
http://www.northerntool.com/webapp/w..._776707_776707
Overkill ain't bad though, 6000 lbs.
Killer stand though.
