Injectors spraying out of the top out of no where.
I was driving home from work yesterday and started smelling diesel while on the highway. When I made it to a light the truck started shaking violently like there was a cylinder or two not firing. When I got home and opened the hood the injectors were squirting diesel out of the top. Anyone know how to fix this cheaply and efficiently?
1993 dodge D350 5.9 cummins
You did not provide your truck details.
On the early (2003 and up) Cummins it was quite common to have one or more injector lines split, mostly #4 & 6. The fix was to add an extra support bracket to stop vibration.
Warning: DO NOT put your hand near the leak if the engine is running. The high pressure diesel leak can easily penetrate the skin leading to blood poisoning
Okay, is there any other ideas before I get to the injector replacement? I am not getting payed too much being in the military 😅
