In-depth video review on new Pro Comp 6 Inch Lift Kit
Old Mar 27, 2019 | 08:48 AM
carid's Avatar
Vendor
Hello everyone! We are back with another video review on the new revolutionary Pro Comp release, that will take customization, appearance, and performance of your truck to the next level - Front and Rear Complete Lift Kit with a 6" Lift. Designed for 2019 Ram 1500 trucks, this kit provides clearance for larger wheels and tires along with adding ground clearance to ensure that your Ram is ready for any off-road challenge. Each Pro Comp kit comes complete with everything you will need to install it on your truck, including the rear cross members, and shocks. Our tech expert Greg examined every aspect of this kit in details in our new video!
Pro Comp® - 6" Front and Rear Complete Lift Kit
https://www.carid.com/2019-ram-1500-...621832990.html
Features:
- Does not fit Rebel model
- Fit Factory Equipped 20" wheels all Coil Spring Models
- Do not fit Air Ride Models
- Max Tire Size: 37"
- Enhanced steering geometry, reduced weight and improved turning radius
- Rear geometry correction brackets and coil spacers maintain the factory load carrying capacity
- New knuckle design helps maintain OEM operating angles of critical components
- Compatible with factory stability control system.
Pro Comp™ | Suspension Systems, Shocks & Lift Kits - CARiD.com
https://www.carid.com/pro-comp/
Improve the look and ground clearance of your Dodge Ram with Pro Comp 6" Front and Rear Complete Lift Kit!
carid
0
Mar 1, 2018 06:08 AM
hwebb
Mar 1, 2010 12:42 PM
Pa outlaw
Jul 30, 2009 09:01 AM
crossy
Oct 18, 2007 08:48 AM
