Compact 12V Jump Starters by Torxe for Diesel trucks at CARiD
If your ATV, lawn mower or project truck was sitting in your garage for an extended period of time, and doesn't show the signs of life, our compact and powerful 12V Car power Banks by Torxe, will jump start it in no time. The starters are available in 2 versions: JS400 14,000 mAh and JS750 21,000 mAh, which makes them perfectly suitable for starting thirsty gas and diesel engines. They are also ideal for everyday charging needs and won't let your smartphone battery drain. Each Torxe power bank comes with various charging cables, jumper cables and 8 charging port adapters. Plus, thanks to the portable compressor from now on the deflated tires are no danger for you at all.
Notes: * 200A Starting Current, 14000 mAh Capacity - Recommended for Gas Engines up to 5.8L, Diesel Engines up to 3.0L; * 400A Starting Current, 21000 mAh Capacity - Recommended for Gas Engines up to 8.0L and Diesel Engines up to 6.0L.; Torxe® - Compact 12V Car Jump Starter with Air Compressor at CARiD https://www.carid.com/images/for-for...compressor.jpg https://www.carid.com/images/for-for...ctual-size.jpg https://www.carid.com/images/for-for...-in-action.jpg https://www.carid.com/images/for-for...smartphone.jpg Don't miss our new video overview of Torxe power banks: More information about Torxe products can be found at CARiD: https://www.carid.com/torxe/ |
