Did I get the right pressure solenoid?
Old Dec 2, 2009 | 11:22 AM
jmac1968's Avatar
I ordered from Transmission Parts USA for a 48RE but the package I just got says D22958 46, 47RE 1996-UP on it. Is it the right one. I hate dropping the pan only to find out I have the wrong part. The transducer says 48RE on it.
This is what I ordered
http://www.transmissionpartsusa.com/...-000053396.htm
Old Dec 3, 2009 | 12:05 AM
p0wd3rp1l0t's Avatar
u r fine, it just doesnt come printed on the bag for some strange reason...i ordered the same exact part from the same exact website lol. i imagine ur replacing the pressure solenoid and the transducer correct? well i just did mine and wow wat a difference. works like new now
Old Dec 3, 2009 | 12:49 AM
jmac1968's Avatar
Yes I bought both at the same time. Plan on doing it Friday. Any tips on the installation? How are the solenoid and transducer held in the transmission?
Old Dec 3, 2009 | 03:54 AM
Nate-03 D's Avatar
Im not seeing a transducer on their site anywhere, I 'm probably in the wrong area through.
I need to order these two parts as well.
p0wd3rp1l0t- Does your tranny just seem to shift better now?
Old Dec 3, 2009 | 03:56 AM
Nate-03 D's Avatar
From what i've heard it just takes simple hand tools to unbolt everything. I believe they are on the side of the valve body. I haven't seen it first hand so don't quote me on anything.
Old Dec 3, 2009 | 07:08 AM
jmac1968's Avatar
Is this what you're looking for?
http://www.transmissionpartsusa.com/...-00053397a.htm
Old Dec 3, 2009 | 10:38 AM
Nate-03 D's Avatar
Yea those two items must be it, I was searching for "transducer".
Just wondering, what CEL codes did you get when these went bad?
Old Dec 3, 2009 | 01:56 PM
RowJ's Avatar
From what i've heard it just takes simple hand tools to unbolt everything. I believe they are on the side of the valve body. .
Both Solenoid and Transducer are on bottom, front, passenger side of the valve body.
Need 7/16" socket and T-25 Torx head.
Drain fluid and remove filter for a while before R+R, unless you have a lift. If not you get drips everywhere.... mouth, clothes, eyes.
Other than that.... easy DIY job!
RJ
Old Dec 3, 2009 | 05:01 PM
hector's Avatar
I'm thinking about replacing mine...
Is it best to use this kit http://www.electricaladvantage.net/a...erkit00up.aspx or, just replace those 2 parts ?? ( transducer & solenoid)
Old Dec 3, 2009 | 09:30 PM
no_6_oh_no's Avatar
Your wasting time and $$ with the OEM junk. The solenoid is the biggest problem. You can live with a slightly off transducer if the solenoid works correctly.
This is much better solution:
or this:
Old Dec 3, 2009 | 09:56 PM
hector's Avatar
The lower unit at suncoast. list for 618re. Where did the top pic come from ?
Old Dec 3, 2009 | 10:06 PM
no_6_oh_no's Avatar
Every 45, 46, 47, or 48 RE is a 618RE in the old designator language. The Suncoast unit is 68RFE BorgWarner solenoid on a custom plate. It will fit every one of these units from 96 to 07.
The top one is from PATC here:
http://www.transmissioncenter.net/dodge.htm
Old Dec 4, 2009 | 09:07 AM
RowJ's Avatar
DTT recommends these GM Solenoid Conversion units. Claim they have had zero problems with them, after over a yr in use.
Just bgt one after my 5th factory solenoid started to hang up before shifting.
Another thread on the subject HERE. if interested?
RJ
Old Dec 4, 2009 | 09:20 AM
no_6_oh_no's Avatar
RJ
Did you get it from DTT?
Got a picture of it?
Old Dec 4, 2009 | 09:40 AM
RowJ's Avatar
Got it from my installer, supposedly at his cost.
It looks identical to your top pic from http://www.transmissioncenter.org/.
Will take a snap shot and post it asap!
RJ
