Cummins Crew Cab Resto Mod Build
Old Nov 3, 2014 | 06:54 PM
  #211
standard81's Avatar
Very interested in this build... I´m in the middle of a restoration as well... Everything is down to nuts and bolts. There won´t be an untouched piece left... I really like the stance and demeanor of the truck with the aftermarket wheels and tires before disassembly for paint... Nice work.
Old Nov 29, 2014 | 05:05 AM
  #212
Jungle's Avatar
Eric,
How much total lift did you end up with on the rear using the stock 63"spring & my hanger combo?
Thanks,
Jim
Old Nov 29, 2014 | 08:17 PM
  #213
CE_TX's Avatar
I didn't actually measure before and after, but it sits level with the 6" I have up front. I also aftermarket spring perches in the rear that may give me a little more lift than what the stock Dana 60 had as well, plus the axle tubes are larger on the AAM 11.5 rear axle I have under there as well.
Old Dec 12, 2014 | 05:43 PM
  #214
flyin6's Avatar
Truly a superior build
Attention to detail is there, as is quality of construction, and some pretty good parts for what this truck is.
Good work!
I have one going on as well...different take than this truck though.
Old Dec 13, 2014 | 07:55 AM
  #215
CE_TX's Avatar
Good work!
Thanks for the compliments.
This build started out as more of a tow rig/drive to the local burger joint in town but it's now pointed in the direction of being a expedition rig. I've got a lot of mods planned to make it a more capable offroader, but it will never be a dedicated trail rig/rockcrawler.
I've read your build on the duramax forum and I like quite a few of the mods you have done, some are definitely unique.
Old Dec 13, 2014 | 08:13 AM
  #216
flyin6's Avatar
My best friend is going to build a 76 crew power wagon like yours. Well, his will be more of a street driven truck, except knowing him it will be like yours and mine, over the top.
The Dodge truck build on D-max forums continues. currently installing the front dana 60 with locker/big axles, hubs and the engine and trans which got the full treatments.
Again, top notch workmanship on your project!
tacoAGGIE
Nov 8, 2013 08:56 PM
lowdown
Cummins Conversions
40
Oct 27, 2012 12:32 PM
moneytlks01
Jul 10, 2012 09:43 PM
Banzai Bob
Mar 3, 2009 01:22 AM
kellypckp
Dec 2, 2005 08:56 PM
