What to do with extra parts...LOL
3 Attachment(s)
I bought 3 non-op CTD trucks,
fixed one> 11' flat bed, 5 speed> 92 Dually other one is a 92 5 speed, flat bed- need to re-seal the pump The last one the body was rough so parted it out Still had the 89 engine and a trans out of an airport tug. When I pulled the 540 out of the Satellite (engine set back 12") looked like a Cummins would fit So, why not...lol Attachment 49972 Attachment 49973 Attachment 49974 |
That is freaking cool! How about some more pics and details on the car?
9 Attachment(s)
Thanks,
I used the trans mount to locate the engine had to remove the P/S and vacuum pump to clear the Steering box even used the CTD radiator, fan and shroud Attachment 49946 Attachment 49947 I'm new to moding diesels for power I have 4.10 and 3.55 gears and a 518 if needed has 4.56 Dana 60 with 31 x 14 - 15 I'm going to put a HE351CW on have done all the free mods also have 60 lbs springs (12) 3800 gov spring need to buy a fuel pin port the head it will be spring until, i can work on it I only have room for 1 project at a time the shop is a section of DC-10>>>lol 28' x 40' presently that is the Rampage It was my DD, >> parts chaser Attachment 49948 until the fuel tank started leaking, then noticed that the uni body was splitting behind the cab The only right way to fix / save it was to put a tube chassis under it, add the 540 Attachment 49949 Attachment 49950 working on the interior sheet metal Attachment 49951 Attachment 49952 Attachment 49953 Attachment 49954 |
2 Attachment(s)
I saw this build over on RCC.
That is one cool Satellite project! Nice work. |
The amount of time and money spent shows in each project. You blended both of my passions. Cool old Mopar iron and Cummins. Your fabrications skills are only overshadowed by your vision. Way cool man, way cool!
I am surprised it took so long for someone else to comment!
The stuff going on in that airplane hanger is COOL. |
Holy Schnikies Dragin!!! Just keep on posting pics of your projects!! That rampage is killer. I'd love more info on that and the Satellite. Is there a build thread somewhere on the Rampage? What's your plans for the Satellite? Going to run it on the 1/4? Don't know if you're a roadkill fan, But the satellite would fit right in on one of thier cruises/runs...
Awesome work man, keep it up |
6 Attachment(s)
Thanks everyone for the comments
been busy with projects living in the shop I'll try to keep to the short version kerry.king had to kick the Rampage out more on that later Opening day was coming close "My anger management class"> Drag Racing only car close to running was the 70 Dart Custom -- "more door" Attachment 49209 Attachment 49210 Attachment 49211 Since I was told not to drive the Dart on the street Cause it sets off alarms, everywhere it goes....lol I was okay with that, cause, I only got a 5 gallon fuel cell I burn 1 gallon @ 1/8 mile.....lol >>> E 85 was a 446 small block 3500/ 4.10 / 275 x 60 - 15 recently swapped to 449 /indy heads / 4500 / 4.56/ / 315-60 x 15 MT pro welded up the exhaust ports/ moved them Attachment 49212 Attachment 49213 Haven't gotten much testing done on that combo yet while at the track testing a few asked about "Where Is the "Shine Runner" Answer: I took the 540 out to put in the 72 Dart I thought about the 21 years The Satellite has been in my care. thought about All the different engines small and big block strokers broke trans, rearends, drive shafts after 2nd time out, broke rear 540 / 4500, transbrake time for a change Attachment 49214 I got interested in the Satellite and installing the Cummins and drive train making custom solid mounts, linkage, etc. even using the 1410 joints . going soon to make some base runs then install 60 lbs springs 3800 governor I did install an electric pump @12psi to feed the injection pump also skipped a tooth, while doing the KDP |
3 Attachment(s)
staying on topic ...lol
Parts from the Satellite,540 went into the next project 72 Dart Swinger The 518 Transmission, is from the car hauler Back to my present project gathering up parts Putting the 72 back together easier to show pic, then me type This is the 72 swinger I'm presently busy with>>> need a street car. floors, truck, frame connectors, wheel tubs, clearance for 518 trans 540/ 518 3.73 True trak / 325-50 x 15 Attachment 49206 Attachment 49207 I want it to look nice, BUT, I want to hear it run>>> Motivational...lol Attachment 49208 |
7 Attachment(s)
Then the Car Hauler (the other 4 door) is next
just needs wiring / paint Attachment 49199 Converted to CTD / 5-speed / 3.07 rear gear Attachment 49200 Attachment 49201 Attachment 49202 There was only one correct way to repair the rust issues in the 73 floor and I wanted to take the easy way out of trying to get all the fire wall mods, dash pad etc. to fit the 73 cab So, I married a 92 Club Cab to the rear section of the 73 Crew Cab Attachment 49203 <a href="http://photobucket.com/" target="_blank"><img src="http://i267.photobucket.com/albums/ii313/draginmopars/cummins/010-2_zpsdfovejs0.jpg" border="0" alt=" photo 010-2_zpsdfovejs0.jpg"/></a> Attachment 49204 Attachment 49205 |
2 Attachment(s)
I grafted the 73 round headlights into the 92 intercooler radiator support
still using the 73 grill / fenders. Tail light assemblys will come from my 73 Cuda to keep the 73 theme on the out side 92 on the inside ps, pb,pdl, a/c, cruise, tilt Attachment 49197 if I only had a bigger shop...lol Attachment 49198 |
8 Attachment(s)
kerry.king
here's the scoop on the Rampage put the 540 in, Then I had a deal working on a super charger, it fell thru, was only a 4-71 so went back to my original plans put a 446, lite weight bob weight> alum rods in changed the converter to match that engine put new tires on, Attachment 49185 Attachment 49186 Attachment 49187 Attachment 49188 Then worked on steering and trans shifter, linkage Attachment 49189 Attachment 49190 next was laying out the interior sheet metal got the drive shaft enclosed, while I studied about the sheet metal lay-out, and where to put the fuel cell and pump. Attachment 49191 at that stage, need to move the Rampage out also made a another hood (skin) lower profile Attachment 49192 decided to put the 540 in the 72 Dart, So, I have a car to drive on cruises Will get back on the Rampage SOON |
1 Attachment(s)
1 Attachment(s)
Finally took the Satellite to the track
Never had so much fun Going so Slow.....lol It leaves quicker than I thought it would started at 5 lbs boost fourth run finally figured out the lights and how deep to stage Now That I got a base # to work with Attachment 49172 Time to crank it up...lol next is Gear change> turn the pump up, gov spring, valve springs |
