Putting a Cummins in a Duce and a half
Has anyone done this yet? My son has a 1969 Duce and a half that the dual fuel engine is questionable at best. He would like to put a 12valve Cummins in it if it would fit. My guess is it would, easily. Could he use an automatic transmission? :conf:
Should be a cakewalk. I believe the military trucks use SAE bellhousings, so get the right adapter and it should bolt in.
A truck that big would require a truck auto, perhaps an Allsion? A place like steel soldiers would probably be a better place to get transmission advice. |
I'll pass that info along. Thank you.
Ide drop a 250 cummin's in it there are plenty around ready to drop in guy bought a bunch of truck's out of Barstow Base but had to cut them up so he has a bunch of motor n trans Packages available . PM me if your interested in info .
Bunch of Duce engines
I'll pass this info along also since the engine in my son's truck is running like crap. Probably bad injectors, even though we just had six new (rebuilt) ones installed.
Thanks a bunch. |
| All times are GMT -5. The time now is 08:10 AM. |
