88 D150 12V conversion
Old 05-26-2012, 12:30 PM
Ram_SRT-10's Avatar
bought the 88 when my 53 block cracked in my 2nd gen truck had 177000 original kms nothing had been touched on it has original paint this i a pretty big deal when you live in southern ontario
bought the rims and tires for 300 bucks and drove it for a year before i got tired of the fuel mileage 10.5 mpg
had my 90 d250 that i drove in high school body was shot frame was shot motor and trans worked great so it was time for a transplant
needless to say swap was pretty straight forward
disassembling the donor
Old 05-26-2012, 12:36 PM
Ram_SRT-10's Avatar
Yuk dirty
Ya! clean
adjusted trans and painted
used diesel rad support as it was diffrent cleaned and painted along with trans cooler and condencer
Old 05-26-2012, 12:43 PM
Ram_SRT-10's Avatar
Prep for paint
decided to remove the lock ring on the ing pump while it was off and easy to get too
KDP Killed
Last burn out with the 318
half ton disassembly
Old 05-26-2012, 12:46 PM
Ram_SRT-10's Avatar
12v painted ISX Red
Old 05-26-2012, 01:02 PM
Ram_SRT-10's Avatar
Good buy fuel hog 318
hello new found power and fuel economy
Old 05-26-2012, 01:06 PM
Ram_SRT-10's Avatar
well found out the my floor pan wouldnt fit the 727 so ...
this sure makes for gettin at those top bolts easy
i know its a cheesy way of doin the floor but i plan on doin a frame off restore on it in the next few years
Old 05-26-2012, 01:11 PM
Ram_SRT-10's Avatar
cab mostly put back together while the dash was out i swapped the harness for the diesel in i know i could have made the gasser harness work but this is much cleaner lookin
sits pretty good for 24 year old 1/2 ton springs
this was a sad day to see my first vehicle go to scrap
Old 05-26-2012, 01:27 PM
Ram_SRT-10's Avatar
first burnout with the 12v
i now get 22mpg and a huge smile on my face
Old 05-26-2012, 11:23 PM
2500's Avatar
what only 22mpg with a 1/2 ton chassis ...
nice job by the way!
my 96 12v gets 22+ mpg on the road. about 20 mpg in town
that's with 265-75r-17 wheels from a 2012 2500 CTD
Old 05-27-2012, 08:23 AM
Ram_SRT-10's Avatar
22mpg was with the quad in the back and my very heavy foot
Old 07-23-2017, 03:23 PM
HimynamesColt's Avatar
New to Forums. Have an 86 150, and a 92 250 with a IC 12 valve. Want to do this swap. What did you do, that you havent listed?
Fab up motor mounts?
Change out the fuel system? New tank?
As for your harness, did you just fully pull the body harness out, or use the Cummins one, and the gas job?
Can I get your facebook info to talk on there? Dont use forums.
Old 07-25-2017, 01:41 PM
Received 2,375 Likes on 1,571 Posts
Colt,
There are 50+ threads on the 1st gen forum that answer all questions.
Using this forum rather than Facebook for the needed info on this swap, would be much better info, in my option.
93 12v
01-11-2010 08:28 PM
smallwwb
07-25-2009 07:55 AM
Troutstrannysvc
Cummins Conversions
03-01-2008 05:13 PM
MoparMarv
03-09-2007 06:04 PM
moparguy
01-26-2005 08:36 AM
Quick Reply: 88 D150 12V conversion
