FJ60 Land Cruiser 6BT Conversion
My '91 Dodge truck was falling apart around it's engine and I was getting tired of chasing vacuum leaks on an underpowered gas engine so started looking for a way to stuff a 6BT in an '85 Land Cruiser.
I'm going to try to post pictures but sometimes have problems with it due to the sites charging for pictures anymore. |
Originally Posted by jakerudy
(Post 3336645)
20+ mpg and more power than I'll ever need.
Originally Posted by Oz_Ram
(Post 3336726)
Nice job Jake:thumbsup: I have an '85 Landcruiser with the Toyota 12HT engine which is a great engine but no comparison to the Cummins power-wise!
My 12V has under 200k on it and has never been abused so should have a lot of life left in it. |
(Post 3336819)
I would not have hesitated to use a Toyota diesel if I had one but parts are harder to find in my area.
I see you have fitted the NV4500 behind it, a wise move as I don't think the Toyota box would handle the Cummins torque. |
Super clean install, looks like a factory job! I guess I never knew the 80's land cruisers were as big as they are.
(Post 3336820)
Even over here, where Landcruisers are very popular, it is getting harder to find parts for the older ones. Most consumables (belts, radiator hoses etc) are only available aftermarket now, other parts I have to get from auto wreckers.
Originally Posted by patdaly
(Post 3336829)
I don't want to deceive anyone - the install was done by a Land Cruiser specialty shop. I do most repairs on my own but this was beyond my expertise.
Had a wrecked '84 FJ60 that I bought for parts, my '85 FJ60 owned for 20 years, '91 Dodge 3/4 ton (falling apart), and 2 NV4500's. Why not make the rig I wanted for years out of this mess? |
(Post 3336835)
Advance Adaptors makes the adaptor from the NV4500 to the Cruiser transfer case. My donor truck had the Getrag 5sp but there isn't an adaptor for it and the NV4500 is superior anyway. The rest of the running gear is original.
The old Cruiser diffs are pretty rugged (I think they are 9.5"), the TC is OK, its biggest problem was stripping the input shaft spline. |
(Post 3336936)
I'm sure with this engine I could break something but you can tear up anything if you try hard enough. It's a great rig and does draw a lot of attention. |
The Cruiser is over 30k miles with the 6BT and runs great. Only problems have been a plugged fuel filter (my fault) and a weak battery that I was able to boost charge enough to start it. Other than that it is just hop in and go anywhere you need.
It is loud by modern standards but for my money you can't beat the simple reliability. It gets over 20 mpg with mixed driving which where I live is more off road than most 4x4s ever see. |
(Post 3364726)
