Engine maintenance in vehicle? Cummins NBS Ford
Old Aug 6, 2014 | 09:23 PM
Pele's Avatar
For those that have swapped a Cummins into a 1999+ Ford SuperDuty, can you easily do engine maintenance with the body in place?
One of the biggest complaints I see about the Navistar 6.0 is that the cab needs to come off to do head work.
I can see the cowl getting in the way with getting to the rear most head studs on a Cummins.
I believe the Ram has clearance for the head studs. Not sure about the Ford though.
Old Aug 10, 2014 | 12:01 PM
enginebill's Avatar
I put a 12 valve in my '05 F-450 and there is plenty of room to work on the engine, there is about 5 inches from the top of the valve cover to the bottom of the cowl.
Old Aug 14, 2014 | 10:13 PM
Destroked F450's Avatar
I have a 12v in my 04 F-450 and can pull all valve covers to adjust valves and torque head bolts. You can't pull the head with studs in the block unless you pull the engine or fit the cab.
Pele
Cummins Conversions
May 21, 2014 06:49 AM
Mike D
Jul 13, 2007 07:23 AM
RC51
Jan 21, 2007 11:03 PM
Smkn600CTD
Jan 17, 2007 12:54 PM
Berak
Mar 22, 2003 08:03 PM
