88 D150 12V conversion
bought the 88 when my 53 block cracked in my 2nd gen truck had 177000 original kms nothing had been touched on it has original paint this i a pretty big deal when you live in southern ontario
https://photos.google.com/photo/AF1Q...Vn0wYIlsQcos4Y bought the rims and tires for 300 bucks and drove it for a year before i got tired of the fuel mileage 10.5 mpg [yuk] had my 90 d250 that i drove in high school body was shot frame was shot motor and trans worked great so it was time for a transplant https://lh3.googleusercontent.com/-x...0/IMG_0305.JPG https://lh3.googleusercontent.com/-q...6/IMG_0303.JPG needless to say swap was pretty straight forward disassembling the donor https://lh6.googleusercontent.com/-h...0/IMG_0340.JPG https://lh3.googleusercontent.com/-A...0/IMG_0341.JPG https://lh4.googleusercontent.com/-v...0/IMG_0342.JPG https://lh4.googleusercontent.com/-r...0/IMG_0344.JPG https://lh6.googleusercontent.com/-Y...0/IMG_0345.JPG https://lh3.googleusercontent.com/-b...0/IMG_0346.JPG |
https://lh3.googleusercontent.com/-3...0/IMG_0352.JPG
Yuk dirty [yuk] https://lh3.googleusercontent.com/-_...0/IMG_0355.JPG Ya! clean https://lh4.googleusercontent.com/-W...0/IMG_0370.JPG https://lh6.googleusercontent.com/-x...0/IMG_0372.JPG adjusted trans and painted https://lh3.googleusercontent.com/-r...0/IMG_0374.JPG https://lh5.googleusercontent.com/-8...0/IMG_0376.JPG used diesel rad support as it was diffrent cleaned and painted along with trans cooler and condencer https://lh6.googleusercontent.com/-K...0/IMG_0382.JPG https://lh6.googleusercontent.com/-z...0/IMG_0381.JPG |
Prep for paint
https://lh4.googleusercontent.com/-H...6/IMG_0387.JPG decided to remove the lock ring on the ing pump while it was off and easy to get too https://lh3.googleusercontent.com/-y...6/IMG_0390.JPG KDP Killed https://lh3.googleusercontent.com/-s...0/IMG_0394.JPG Last burn out with the 318 [laugh] https://lh3.googleusercontent.com/-e...6/IMG_0391.JPG half ton disassembly https://lh3.googleusercontent.com/-A...0/IMG_0393.JPG |
Good buy fuel hog 318 [yuk]
https://lh6.googleusercontent.com/-y...0/IMG_0401.JPG https://lh4.googleusercontent.com/-z...0/IMG_0402.JPG hello new found power and fuel economy https://lh4.googleusercontent.com/--...0/IMG_0403.JPG https://lh5.googleusercontent.com/-s...0/IMG_0407.JPG https://lh5.googleusercontent.com/-J...6/IMG_0418.JPG |
well found out the my floor pan wouldnt fit the 727 so ...
https://lh3.googleusercontent.com/-f...0/IMG_0404.JPG https://lh3.googleusercontent.com/-P...0/IMG_0405.JPG this sure makes for gettin at those top bolts easy [laugh] https://lh3.googleusercontent.com/--...0/IMG_0409.JPG i know its a cheesy way of doin the floor but i plan on doin a frame off restore on it in the next few years https://lh3.googleusercontent.com/-5...0/IMG_0414.JPG |
cab mostly put back together while the dash was out i swapped the harness for the diesel in i know i could have made the gasser harness work but this is much cleaner lookin
https://lh4.googleusercontent.com/-z...0/IMG_0420.JPG sits pretty good for 24 year old 1/2 ton springs https://lh3.googleusercontent.com/-7...0/IMG_0411.JPG https://lh3.googleusercontent.com/-J...0/IMG_0410.JPG this was a sad day to see my first vehicle go to scrap https://lh5.googleusercontent.com/-x...0/IMG_0426.JPG https://lh6.googleusercontent.com/-j...0/IMG_0427.JPG |
Originally Posted by Ram_SRT-10
(Post 3107801)
nice job by the way! my 96 12v gets 22+ mpg on the road. about 20 mpg in town that's with 265-75r-17 wheels from a 2012 2500 CTD |
22mpg was with the quad in the back and my very heavy foot
New to Forums. Have an 86 150, and a 92 250 with a IC 12 valve. Want to do this swap. What did you do, that you havent listed?
Fab up motor mounts? Change out the fuel system? New tank? As for your harness, did you just fully pull the body harness out, or use the Cummins one, and the gas job? Can I get your facebook info to talk on there? Dont use forums. |
Colt,
There are 50+ threads on the 1st gen forum that answer all questions. Using this forum rather than Facebook for the needed info on this swap, would be much better info, in my option. |
