04 f350 6.0 to 24 valve swap
Time to start my new project. I just picked up a 04 f350 with a 6.0 power stroke. I going to swap a 99 24 valve in it's place. I'm planning on using destroked engine swap motor mount kit. I'm not sure if i'm going to use the ford 5 speed torque shift tranny or not. We'll see how it goes.
Sounds like a great project. Am looking forward to reading about your progress.
After seeing how common and expensive CR injector failures are, I wouldn't ignore the VP44 24 valve as a suitable donor, both seem to have their strengths and weaknesses.
1 Post
you wont need much from the donor truck. you will need the throttle cable. use a cr exhaust manifold and the turbo will fit better. the torque shift tranny is a good auto behind the cummins once you get it working right with the controller. Fordcummins.com has it pretty much figured out. I ran the ford alt and starter.
jagarcia89
04-25-2013 01:34 PM
