zanesville ohio pull sept 29
anyone know were the rules are posted yet and who all is going?
wife, son and i are going for sure ...
if they get a dyno to show we'll bring three trucks ... sounds like a good time[guitar] |
as far as i know no dyno be nice if they do id like to dyno mine if i dont break it
What event is this associated with in Zanesville. Im only a couple of hours away. Which and how many classes of diesel trucks are pulling?
what classes and where is zanesville?
ohio there running street 2.5 charger, super street 2.8 charger, modified and a few tractor classes not sure wich ones.
thought i'd bring this btt as it's gonna be this weekend
check out the prize money ... we'll have 2 or 3 trucks going up ... SOUTHEAST OHIO PULL WE WILL BE HAVING A BIG PULL ON SEPT.29TH AT THE MUSKINGUM COUNTY FAIRGROUNDS. THERE ARE ALOT OF BIG SPONSORS ON BOARD FOR THIS PULL. WE WILL BE HAVING A FEW GIVEAWAYS THERE WILL BE PLENTY OF SMOKE AND SOME GREAT FOOD. PULL ORDER 6500 PROSTOCK GAS 8000 STREET DIESEL HOT FARM TRACTORS 8000 SUPER STREET DIESEL PRO STOCK TRACTORS 8000 MODIFIED DIESEL CLASSES: 8000 STREET, 8000 SUPERSTREET, 8000 OPEN. HOT FARM, AND PRO STOCK TRACTOR CLASSES, 6500 PROSTOCK GAS. THERE IS 7500.00 UP FOR GRABS IN THE PICKUP CLASSES. FOOD WILL BE PROVIDED BY THE MUSKINGUM COUNTY CATTLEMENS ASSOC. GATES OPEN AT 2PM, TECH STARTS AT 3PM, PULLS START AT 5PM. STAY TUNED FOR MORE INFO OR CALL 740-819-0457 RULES FOR THE DIESEL TRUCK CLASSES STREET CLASS 1. ALL TRUCKS WHO PLACE IN THE MONEY WILL BE TECHED! 2. 8000 lb Dual Rear Wheels Allowed 3. No Nitrous, Propane, Alcohol, etc. #2 Diesel Only 4. Water Injection 5. Hanging weights allowed, furthest point must not exceed 60” from C/L of front axle All weights must be secure; disqualification may be enforced if weights fall off. 6. Must have full interior, exterior. Has to remain street legal 7. Must provide license and registration 8. Single Charger only limited to maximum of 2.5” wheel. Reducers, plugs, etc. can be used to make a large wheel charger “fit” into this class. Chargers will be teched. 9. DOT tires, no studs, no cut or sharpened tires. 10. No aftermarket transfer cases or transmissions. 11. Rear suspension must have a minimum of 1” of travel. 12. Must pull from Reese style hitch or factory bumper. Hook point must be at the furthest most point of the vehicle. Hook point must be at least a 3” OD ring or clevis. 13. 26” Hitch Height 14. Traction/ Ladder bars allowed 15. Exhaust must exit straight up or straight down- No exceptions. 16. Puller will be allowed a total of two attempts within the 100 foot mark to start the sled. Test puller may drop and come back in sixth position. 17. Engine must be out of factory 1 ton or smaller pickup 18. Bellhousing blankets required for engine turning over 4200 RPM. 19. Rear U-joint shields required. Driveshaft loops highly recommended 20. Track and Tech official’s decisions are FINAL SUPER STREET 1. ALL TRUCKS WHO PLACE IN THE CLASS WILL BE TECHED! 2. 8000lb limit (Dual rear wheels allowed) 3. No Nitrous, Propane, Alcohol allowed. #2 Diesel Only 3. Hanging weights allowed, furthest point must not exceed 60” from C/L of front axle All weights must be secure; disqualification may be enforced if weights fall off. 4. Single charger class with max. 3.0 wheel. 5. DOT tires, no studs, no cut or sharpened tires. 6. No aftermarket transfer cases or transmissions i.e. Dropboxes, Reversers 7. Factory rear suspension may be blocked, no custom rigid suspensions allowed. 8. Hitches: Reese style hitch, factory bumper or under bed hitch. Hook point must be 48” from the centerline of the rear axle. Hook point must be at least a 3” OD ring or clevis. 9. 26” Hitch Height 10. Traction/ Ladder bars allowed 11. Exhaust must exit straight up or straight down 12. 4500 RPM limit. 13. Engine must be out of factory 1 ton or smaller pickup 14. Trucks that place for the payout will be teched (to be determined) 15. Bellhousing blankets required for trucks that do not meet the Street Stock rules (over 4200rpm) 16. Driveshaft loops required for trucks that do not meet the Street Stock rules (if your in this class you should have loops) 17. Water Injection permitted 18. Fire Extinguishers required 19. Injection pump must be stock appearing (for example: No Ag governor on P Pump). Dual CP3 pumps allowed. 20. Track and Tech official’s decisions are FINAL. 8000LB. OPEN CLASS 1. 8000 lb 2. Diesel only 3. 4X4 Truck 4. 26” Hitch Height 5. Blow proof bell housing or blanket, kill switch, driveshaft loops, exhaust must exit up or down, helmet. 6. Track and Tech official decisions are FINAL. ANY QUESTIONS PLEASE CALL 740-819-0457. AS FOR THE GAS CLASS IT IS A 6500LB PROSTOCK CLASS. PLEASE CALL WITH ANY QUESTIONS ON IT AND I WILL GET YOU THE ANSWER. WE ARE RUNNING THIS CLASS AS A FAVOR AND HAVE NOT BEEN GIVING |
