-   Competition / Pulls / OffRoad (https://www.dieseltruckresource.com/forums/competition-pulls-offroad-108/)
-   -   What Gear for pulling??? (https://www.dieseltruckresource.com/forums/competition-pulls-offroad-108/what-gear-pulling-133815/)
jsflagstad Jan 24, 2007 09:05 PM
Thinking about running in a few local pulls around here this next season and I'm looking for some advice. I have a 2002 Ram 2500 HO with a 6 speed. The truck has 285 / 75-15 all terrain tires. I will be adding a 5" exhaust and an intake.
The questions I have are:
Tire pressure?
High or low on the transfer case?
What gear on the tranny?
Is there a particular ground speed that I should look for and pick a gear accordingly?
Any other pointers or advice???
Thanks,
JSF[guitar]
blackdiesel Jan 24, 2007 09:13 PM
Tire pressure? - 15~20 psi
High or low on the transfer case? - low
What gear on the tranny? - 3rd
Is there a particular ground speed that I should look for and pick a gear accordingly? N/A
Any other pointers or advice??? - sounds like your trying to take you clutch out. because you will if you dont be careful!
if your going to pull on the stock clutch, use 2nd on the low side. Wont get as far, but its better than dropping the nv5600!
Thanks,
JSF[guitar]
stupidcharacterlimit
mr T Jan 24, 2007 10:01 PM
Tire pressure?
Thanks,
JSF[guitar]
...only thing i know is that most guys launch with the gear that gives them 1:1 ...with the 5 speed its 3rd...they rev it up nice and high to build tons of boost and launch with some slipping of the clutch in 4H...the truck stays in that gear the whole way
jd4440 Jan 24, 2007 10:19 PM
i have pulled a couple of times and scored some first but i have a 5 speed and i pulled in 3 gear which was said, the valair clucth does not like that either, but i have pulled with a guy with a 6 speed he had a comp,150 jammers,intake and exhaust, dual disk SB with 37" MTs pulles in 4 gear low, i usaully run 12 psi in the tires and put some blocks in between the rear axleand the stops so they just touch the rubber so you will still have 1" of supension (dont tell any one) and put a big bummper off the front
59Dsul Jan 24, 2007 10:35 PM
6 speed with 4.10's, a good clutch, and decent power....4th low
6 speed with 3.55's, a good clutch, and low to decent power....3rd low
Direct drive (1:1) is 5th on a 6-speed or 4th on a 5-speed. This should only be used in low range. It takes a good bunch of power, a good clutch, and quite a bit of slip (on a good midwestern clay track) to make it work. And it isn't really a 1:1 because of the transfer case reduction. There is no way I would ever try high range in any gear approaching direct drive.
andy
Muddin_dude06 Jan 24, 2007 10:43 PM
1:1 in a 5 speed is 4th gear, I don't think you would do any good in high. I think most people use 3rd low or maybe 4th low. When I sled pull I plan on using 3rd gear Low...
PourinDiesel Jan 24, 2007 11:07 PM
JSflagstad,
I wouldnt even bother sledpulling with stock power.
If you do run 2nd gear low range on the transfer.
satburn Jan 24, 2007 11:21 PM
Originally Posted by PourinDiesel (Post 1318642)
JSflagstad,
concurred.
95ram Jan 25, 2007 01:58 AM
I'm going to have to disagree guys. I did about 5 pulls on my stock clutch. All in 3rd low. The key is dont slip the clutch. What I did was bring the RPM's up to about 1800 and start letting the clutch out. It would slip a little but not much. It worked pretty good. This was with a PM2.
Redline Ram Jan 25, 2007 06:17 AM
Originally Posted by 95ram (Post 1318788)
What I did was bring the RPM's up to about 1800 and start letting the clutch out. .
that is slipping the clutch
HOOKED Jan 25, 2007 07:25 AM
JSflagstad,
Agreed!! No point in tearing stuff up when you havent got a chance in winning.
jsflagstad Jan 25, 2007 07:28 AM
Don't Bother??
In my area, the pulls I have went to to watch, they have classed all of the pickups by weight regardless if they were gas or diesel. From what I have seen there is a stock class (Intake and exhaust) and then a mod street (chips, Intake, and exhaust) class and then a full mod class. The stock class is usually flooded with lots of gassers with a few diesels sprinkled in and 99% of the time the diesel take the win.
I am just in it to have some fun, as I'm sure all of you are. I drag raced for years and even won a national title and didn't make a dime, but I sure had fun and I'm sure that pulling is much the same.
JSF
JDGnut Jan 25, 2007 12:52 PM
15-20??? Maybe on the front.. not on the back.....
strokethis600 Jan 25, 2007 12:57 PM
JSF
Must be nice to pull in an actual stock class. Around here a "street" stock diesel class starts at about 500-600 hp with some just being trailer queens.
WhiteSport600 Jan 25, 2007 01:06 PM
Amen to that!!! Wait, that's me...lol
js-- Don't bother on a stock clutch. Put a DD in it if you want to pull, if you don't, you'll be trailering home.
