Top 7 reasons I'm not going to make it to Stoneboro for the DHRA pull
Well with the odds stacks against me, I finally have to accept that I'm not making it to PA... Heres the top 7 reasons I'm not making it to PA.
7. No AC 6. Alternator Doesn't Charge batteries 5. Transmission in LIMP mode (3rd gear only) 4. No Dash gauges (speedo,odometer,tach) 3. http://www.puredieselpower.com/pics/...frontshaft.jpg 2. http://www.puredieselpower.com/pics/.../rearshaft.jpg http://www.puredieselpower.com/pics/...rearshaft2.jpg And the number one reason I won't make it to the Stoneboro PA DHRA pull: http://www.puredieselpower.com/pics/amherst/fluid.jpg All transfer case fluid.. Its cracked. Here is the video. Edging up on 15PSI of boost: http://thumbs.vidiac.com/39bcec5e-91...969145e2b3.jpgClick here to see Video |
Got Torque?
Sorry to hear of the carnage - hope you get it fixed soon! |
i wanna punch the guy who says "it's a dodge.." in the end of the video [laugh]
hope nothing else broke and u get the shaft replaced soon |
That sound is about enough to give ya nightmares....
In all fairness, the crank sensor is to blame for all these symptoms:
6. Alternator Doesn't Charge batteries 5. Transmission in LIMP mode (3rd gear only) 4. No Dash gauges (speedo,odometer,tach) brandon. ;) |
So THAT'S what driveshaft loops are for.......:(
Ouch! At least the sparks were pretty, right? :D
Wow, I just watched it 3 times and I REALLY want to knock the "its a dodge" guy out. [verymad]
Dayum Garrett!!! I guess you will be making the appropriate changes to your posting signature now? I would define that as "carnage".
Garrett hope you get it all fixed quickly....
Mines down at the moment too... |
Mines down at the moment too... I hope I can get it fixed as well.. Hopefully within 2 weeks.. I gotta figure out if my transfer case can be welded.. I don't THINK anything internal is shot. |
Thank god for drive shaft hoops. That would have pounded on the block pretty hard if given the chance!!
