Streeet Truck Pull Springfield Tn.
Truck Pull SpringField Tn June 27th
Gates open @5:30 Pulling starts at 7:00 This is a Street Truck Pull this gives the Strret trucks a chance to compete.
Originally Posted by Rules and Classes
General Rules:
1: Owners must drive their truck to tech. Owners must present a current insurance card, vehicle registration, and valid driver’s license to register. The license and VIN must match the truck. If the registering participant is not the owner of the vehicle, he/she must be present at the time of technical inspection and have a valid drivers license. 2: The hitch’s height from the ground may not exceed 26 inches 3: All weights and loose articles must be secured. All extra weights must be secured in bed. 4: Pull Vehicle Must have DOT approved tires. NO cut tires. 5: No Nitrous or Propane! 6: Puller must provide 2.5”ID or larger clevis. 7: ALL participants MUST wear seat belt. 8: Trucks must meet street legal requirements. (Lift kits are acceptable) 9: If they are hauled in, you WILL go into unlimited class. 10: 16-17 years MUST have written parent's consent. 18 and over - driver assumes full liability. 11: Only 1 person per truck when pulling. Violators will be disqualified. 12: Trucks will be inspected at gate and weighed and classed accordingly. 13: Any announcements or rules made/changed the day of the event, if needed, supersede these rules. 14. Puller will be disqualified if management is suspicious of Driver being under the influence of drugs or alcohol. 15. Only the driver will be permitted in the truck when pulling. 16. All trucks must be one-ton or smaller in capacity. 17. Exhaust must extend behind cab and exit through stacks in the bed or in the OEM location. The unlimited class exhaust may exit through hood. 18.Truck inspections, before or after the pull, that find violations to the following rules of their Pull Class will result in an immediate disqualification of truck and driver; all registration fees will be forfeited; and all prize will be forfeited. General Procedures: 1: First truck out in each class can decline the distance and come back as the 3rd Puller. 2: Puller will have 2 chances to get past 75 feet marker. 3: After starting a pull, no shifting is allowed (Manual Transmissions). 4: Track judge’s ( flaggers / officials) decision is final. Classes: 1: Stock Diesel This must be a completely Stock truck! No programmers or chips allowed. Must have stock exhaust and intake. 8500 LB. weight limit. No aftermarket Gauges. 2: 7500 LB. Diesel. Must weight less than 7500 Lb.'s Must have a stock Turbo No Hanging weights Must have at least 1" on travel in the rear. No Water injection receiver style hitch required Must be driven in the gate. 3: 8500 LB. Diesel Must weight less than 8500 Lb.'s Must have a stock Turbo No Hanging weights Must have at least 1" on travel in the rear. No Water injection receiver style hitch required Must be driven in the gate. 4: 10,500 LB. Diesel Must weight less than 10,500 Lb.'s Must have a stock Turbo No Hanging weights Must have at least 1" on travel in the rear. No Water injection receiver style hitch required Must be driven in the gate. 5: Unlimited Diesel Truck must weigh less than 8500 LB. No Nitrous or Propane. Hanging weight's accepted Water injection accepted |
I'll be there. I pulled last year, but had pump problems and didn't do so well. Got everything fixed, and I am looking forward to Friday!!!
