Strapping Front Axle
Had A Friend Tell Me To Strap Down My Front Axle On Both Sides Buy The Shocks
To Stop The Wheel Hop At High Rev Has Anyone Else Tried This ON MY GEN 1 |
I asked that question a long time ago, and I was told, that it wreaks havoc on front driveline components.
Originally Posted by apocalypse1812
(Post 2780846)
seen it on later model fords, but I never stopped to look very hard.
It can be done, the trick is to ensure you don't compress it so much it screws up your pinion and transfer case angles, when the rear end squats. Takes some trial and error. You might look at air pressure adjustments as well and some new shocks. I have seen several gas pullers us it on leaf spring front ends. Around here not many people pull with 1st gens and the coil and control arms take care of most of it.
| All times are GMT -5. The time now is 07:26 AM. |
