Michigan, Sept 12th #8000 Hot Diesel $1500+ Purse
1 Attachment(s)
This Saturday Engineered Diesel is sponsoring an #8000 Hot Diesel class up in Kent City, Michigan. Purse is at $1500 so far, working on getting first place to $1000 and paying top 5 places. $25 entry fee. Rules and event flyer below.
MTTP HOT DIESEL UNLIMITED TRUCK RULES All decisions made by a MTTP official are final. HOT DIESEL The Hot Diesel Unlimited class is designed for full -bodied 1 ton or less pulling trucks. With a maximum weight of 8000lbs. DRIVERS: Must be 16 years of age. All drivers must have a valid driver’s license. Drivers shall not be under the influence of drugs or alcohol, and must drive their trucks in a safe manner at all times when at the pull. BATTERIES: Batteries must be securely mounted. They may not be located in the driver’s compartment. BODY: Fiberglass hoods are prohibited. CHASSIS: Wheel tubes, back-half conversions, tube chassis, etc., are all prohibited. BALLAST: Ballast is permitted. Hanging weights are permitted but must be securely mounted and may not extend more than 60 inches from the center line of the front axle. DRIVELINE: An OEM transmission, transfer case, and axles is mandatory. It must have been optioned in a one-ton or smaller pickup. DRIVER RESTRAINT SYSTEM: The OEM restraint system is mandatory and must be worn. Or a three inch wide driver restraint system labeled as meeting SFI Spec 16.1. DRIVESHAFT LOOPS: All trucks must have at least six inch wide u-joint shields around all drive shafts u-joints, u-joint shields must be constructed out of at least ¼ inch steel or 3/8 inch aluminum with the u-joint centered in it. In addition there must be at least one drive shaft loop in the middle of each drive shaft. ENGINE: The engine block must have been available in a one ton or smaller pick-up truck. EXHAUST: All vehicles must be equipped to direct exhaust upward or downward. Two 3/8 inch min. diameter bolts must be placed in the exhaust pipe in a cross pattern within one inch of each other as close to the turbo as practical. FIRE EXTINGUISHER: A fire extinguisher is mandatory. It must be easily accessible and visible. AIR SHUTOFF: The vehicle must be equipped with an air shutoff. A master control for your air shutoff must be located at the back of the vehicle next to the hitch point; it must have a two inch diameter steel ring and be clearly visible to the hook man. A fuel shutoff is also very highly recommended. FUEL INJECTION PUMP: The fuel injection pump is limited to a stock appearing, OEM engine model-specific pump only. Twin CP3’s and Hpop’s are permitted. HITCH: The hitch must be a “REESE” style hitch. Reinforcements are permitted. "Drawbar" style hitches are permitted. The hitches height from the ground may not exceed 26” for 4x4 and 30” for 2x4. Must have a hook point at least 44 inches from the center of the rear axle. The hooking point must have a minimum 3.00 inch by 3.75 inch inside diameter opening for the sled hook. NITROUS OXIDE: Nitrous oxide is prohibited. No other oxygen extenders are allowed. PROPANE: Propane is prohibited. REAR SUSPENSION: Traction bars and devices are permitted. Suspension must maintain a minimum shock travel of 1 inch. TIRES: Tires must be DOT street tires. Cut tires are prohibited. A maximum tire diameter of 35 inch. TRANSMISSIONS: Transmissions (manual and automatics) must have a transmission / bell housing blanket meeting SFI 4.1. TURBOCHARGER: There is no limit on Turbocharger size or configuration. WATER INJECTION: Water injection is permitted. chris@engineereddiesel.com 616-608-2977 glenn@engineereddiesel.com 616-890-1470 |
To define the rules further.....Ag pumps are allowed.
Hood stacks are allowed. First place is $1000. 2nd through 5th is $350, $200, $125, and $75
| All times are GMT -5. The time now is 03:45 AM. |
