Diesel Trucks Wanted Sled Pull Near Houston Mo
#46
LOL, thorough ain't I? I've just seen enough people get mad over this same ol' stuff that I pretty much know ahead of time what you're going to have troubles with. I'm just trying to help you take care of a lot of stuff upfront instead of "day of".
The 4th question I need a little more clarification, you left it a little vague yet.... sorry man. Yes it can be stopped if you choose. Those two governors are visually different and once you know what to look for it can be easily identified. But it's your choice. Your response seems to suggest that you are going to allow them. So is it yes or no?
The 5th question seems to suggest as long as you make an attempt you are ok. The DOT registration is going to be hard to swap from the tow rig, but as long as it has plates, you're good to go? Is that correct?
#48
Alright, so you'll consider a Super Street (Or Open) class for Ag Govs if enough show up? Otherwise no Ag Govs in the Street Diesel class?
I don't mean to put you on the spot Corey, just want to make sure it's clear. Thanks.
#51
#52
Alright, then we'll simplify things in one post.
Houston Pull
DHRA Rules (Street Diesel - Work Stock)
http://www.dhraonline.com/main/forms...ook-v2.7.1.pdf
See your class section for details
Houston Pull
- No Ag Governors in Street Diesel Class (May offer a Super Street / Open Class for Ag Governors if enough show)
- No Helmet or Fire Suit Needed
- No Air Shutoffs Needed
- Plates Required for Street Diesel Class
- 4,500 rpm Rule (Puller must provide proof of RPMs if questioned, otherwise prize money will be forfeited)
- Drive shaft loops, Upward exhaust, Cross bolts in exhaust & Fire extinguisher waived for first time pullers, but suggested for safety.
- No 2.5 turbos in Work Stock Class
#54
https://www.dieseltruckresource.com/...2&postcount=10
7,710 rpm when she let go.
Corey you'll want the sound, she sounds GOOD!
#55
Right on the Button Sat. I dont have the words like you ,glad you looking out for me tonite.Thats pretty clear. Now if I can git the trucks I hope for will be set lol :-)
#56
I do... or at least somebody threw a number out there.
