Danville Indiana truck & tractor pull Sept. 13 12pm
Old Aug 26, 2008 | 10:29 PM
torquet's Avatar
Truck pull at the Hendricks County Fairgrounds in Danville, Indiana on September the 13th at 12pm.
sled pull to benefit the Hendricks County 4H group and in conjunction with the Hendricks Co. Fair Board, Sharpier Images Sign co., Danville Performance, Fleece Performance, and a big list of Sponsors it was made possible, Thank you! There will be eight classes to pull, gates are opening around 10am and pull will start at noon. Here are the rules and if there are any questions the numbers are on the bottom.
Danville Sled Pull Rules for Sept. 13, 08
No alcohol allowed & coolers subject to search, No riders allowed, must be 12+ to be in pits
Not responsible for accidents or lost property
$35
Hook fee( comes with 2 pit passes), $15 pit pass, $7 admission & 6 and under free
Concessions will be available from Lovin Spoonful
Classes:
1. 4x4 Altered Stock Gas 6,500lb Class
-26in hitch height
-Headers downward-cast iron heads
-Blocked suspension legal
-NO front weight brackets
-O.E.M. front bumper in factory location
-any front weight must be behind front bumper
-NO pipe bumpers
-traction bars legal
-D.O.T. street tires only
2. 10,500lb 9mph Tractor Class
-20” Drawbar height
3.WorkStock Diesel Truck 8,000lb Class
-2.5” inducer bore max, new 6.4L Ford with factory un altered twins are allowed
-single fueled only, no sigma pumps
-26” hitch height Reece style no trick hitches allowed
-1” suspension travel
-Traction bars are legal
-1 ton or less drive train with D.O.T. non-cut street tires
-no water or drugs
-no hanging front weights
-license and registration needed and truck must be street legal
4.10,500lb Open Tractor Class
-20” drawbar height
5.Street Diesel Truck 8,000lb Class
-2.6” inducer bore max
-dual fuelers allowed, dual hpfp’s allowed
-no water or drugs
-hanging front weights allowed
6.13,000lb Tractor 9mph Class
-20” drawbar height
7.Pro Street 3.0 Open Diesel Truck 8,000lb Class
-3.0” inducer bore max or twins with 3.0 max on atmosphere charger
-26” hitch height reece style no trick hitches allowed
-no water or drugs
8.13,000lb Open Tractor Class
-20” drawbar height
Payouts:
Tractor Classes- $100 first $75 second $50 third
WorkStock $150 first $75 second $50 third
Street Diesel $250 first $150 second $75 third
Pro Street $250 first $150 second $75 third
Contact info:
tractors and gas trucks: Brian Rutledge 317-710-0393
diesel trucks: Danville Performance 317-745-8587
Fleece Performance 765-676-5063
George (me) 812-677-0990 will post more info as it comes available
Old Sep 4, 2008 | 01:35 PM
torquet's Avatar
BUMP to the top
Old Sep 5, 2008 | 12:27 PM
jwb600's Avatar
george I may go if I dont have to work but dont know yet. as usual if I dont hang weights I would get beat and still not setup yet need to fix that
Old Sep 5, 2008 | 03:22 PM
torquet's Avatar
you can use my bracket, it bolts right on where the tow hooks do. I am staying in the little 2.5 class. Hope we have a big turn-out
Old Sep 5, 2008 | 09:28 PM
jwb600's Avatar
I thought the bumper has to come off to get the tow hooks off? maybe I was wrong
Old Sep 5, 2008 | 09:43 PM
RAT_03's Avatar
DTR's "Secret Agent"
Bumper does have to come off. At least it does on the 03s and 04s
Old Sep 6, 2008 | 02:00 AM
House's Avatar
4 pulls that day, in indiana
Old Sep 9, 2008 | 05:18 AM
torquet's Avatar
Mine didn't have any, guess I was lucky. You still can use it if you want to.
Old Sep 9, 2008 | 11:50 PM
jwb600's Avatar
thank you george if Im off work I may just come and watch your full pull
Old Sep 10, 2008 | 12:45 AM
RAT_03's Avatar
im going to try to make it up and then convoy my butt back to lanesville. double hitter!!
Old Sep 10, 2008 | 05:57 AM
torquet's Avatar
Had a meeting last night to make sure everything is in-line. I think it is. I guess there are some trucks and tractors coming from Peoria, Ill. Also alot of talk about some pulling double duty like RAT 03. Hopefully I get to see everyone. If the weather doesn't cooperate we are thinking of a make-up date of Oct. 4th, have to check with Lowery though. But we plan on tarping the track thursday night.
Thanks everyone.
Old Sep 12, 2008 | 08:22 PM
torquet's Avatar
We tarped the track Thursday before it started raining. Almost all of the track is dry. A few wet spots were the rain ran under the tarp but, when we disk it up in the morning everything will be ok. We are meeting at the track at 6am to see if it rained anymore overnight. We have to call Lowery's by 0630am. If we don't get alot of rain tonight we should be ok. Hopefully no rain tomorrow though.
Thanks George
Old Sep 13, 2008 | 02:32 AM
jwb600's Avatar
any word if its cancelled. it has rained alot around here. they pulled at lanesville and got zero rain down there but we got rained on driving down. I know its shocking but reisert won it haha man that truck runs he let off at the end of the truck so he didnt run thru the sand/dirt pile and the plywood fence
Old Sep 14, 2008 | 01:30 PM
jwb600's Avatar
sorry I didnt make it up george had to be at work at 1am. did you pull how did you do?
Old Sep 15, 2008 | 07:23 PM
torquet's Avatar
5th out of quite a few. 293ft. 301ft won I believe. I dont know if it would have mattered but I did forget to turn the van aaken on all they way.
