1000+hp d-max
check out the link
Link removed- Do not post links to ant site that contains profanity Thank you begle1 for pointing out this violation so I could remove it |
Do you see the guy called McRat with the first response?
Yeah, I clean his swimming pool... Small world... 1000 HP/ 2000 Ft. Lbs is pretty wild. It's reflective of how the V-8 puts out more horsepower per foot pound; a P-Pumped Cummins with 2000 foot pounds is putting out 800 horsepower? |
Originally Posted by iker42
(Post 1322726)
No Dyno sheet? No Pics? Nothing.... btw our trucks putting down 2500[nonono] hp....cough cough
You should be ashamed of yourself. I don't doubt their numbers for a second. On another note, this dyno event was three miles from my house. If I drive out there now I could probably get some pictures for you... |
Originally Posted by Begle1
(Post 1322734)
(Post 1322738)
thats all i ask for is a dyno sheet...jeeze no trolling involved
Originally Posted by 79warlock
(Post 1322739)
Or does the Cummins just put out more lb-ft per hp?
(Post 1322739)
Originally Posted by summit889
(Post 1322765)
cummins typically makes peak torque at a lower rpm. hp= tq.x rpm/5252 so if 2 trucks make 1000 ft. llbs. but one does it at a lower rpm that truck will have a smaller hp number.
(Post 1322765)
Congrates to the D-Max crew and their great numbers.
Was that number with the stock internals? |
(Post 1322800)
Well, there's a little more to it than that. To a certain extent, peak torque and peak hp are independant. It was meant as a joke...
Originally Posted by Andy505
(Post 1322825)
I'm gonna have to disagree with you on that....Horsepower and torque are directly related. Horsepower is calculated from torque at a certain RPM, and they are both ALWAYS equal at 5252 RPMs
We really need to see the dyno because, at this point, we are just guessing where that truck starts making it's torque.
Originally Posted by Mike D
(Post 1322820)
Was that number with the stock internals? Chris |
1000 + HP D-max
That is just freekin incredable! Congrates to to all involved.
Scott |
(Post 1322734)
