-   CODTR #26 (https://www.dieseltruckresource.com/forums/codtr-26-130/)
-   -   Recommended Shops in Colorado (https://www.dieseltruckresource.com/forums/codtr-26-130/recommended-shops-colorado-239889/)
sledskiing 04-12-2009 10:48 AM
Looking for a shop to do some performance work and bling work in Colorado (Denver area) any recommendations?
bansheetroy 04-14-2009 09:45 PM
shop
look up holand court diesel john is a great guy!!!!!!!!!!!!!!!
BarryG 04-15-2009 06:51 AM
You might try the following they have all done good by me in the past
Colorado Diesel in Castle Rock, Tyler 303-660-9986
PDT in Greeley, Lazerbob 970-356-6444
Performance Car & Truck, Rob 13200 w 43rd #106 ,roughly I 70 and Ward rd . 720 560 0554
STate 04-15-2009 08:49 AM
I recommend Bill Bernard @ B and A automotive. off 285 and Hampden in Englewood. 303-916-1649. He's a cummins guy.
and also Sean @ L1 automotive in Burthoud. Another cummins guy. 970-532-0373
The_Head 08-28-2009 09:36 PM
More recs please.
Where are the diesel dynos at?
How about shops that do custom stuff? I'm dreaming about an 04.5-07 motor/trans in my '92. If I get deployed, it's going to happen...
GLHS 08-30-2009 09:00 AM
All of the above are what came to mind and I'll add one which may be or was related to L1 in Berthoud; Jeremy @ Lowry Motorsports 970-443-3942
Troym61 09-03-2009 09:39 PM
You need to call Rob (Maxtorq) he is the BEST at everything Cummins,
Building a very high performance twin set up.
303-278-8038
crob1 10-11-2009 07:48 PM
I also recommend Rob (Maxtorq) of Performance Car and Truck. He also owns DieselRam.com. He's thorough and fair priced. He's the only one that works on our stuff.
MAXTORQ 11-17-2009 06:23 PM
Thanks for the recommendation guys .
Big Oil 11-25-2009 07:31 PM
I'll second Jeremy @ Lowry Motorsports 970-443-3942
84mphcdt 10-05-2010 07:42 PM
any new recommendations for shops ? - i'm possibly needing one to have a ctd for sale checked out
crob1 10-05-2010 08:13 PM
We've recently had some work done at 5R in Golden. I don't know if they do that sort of thing, but they might. We were real happy with them.
baddodges 10-06-2010 06:31 AM
ATS PERFORMANCE ward road in arvada.
calltrex 10-17-2010 11:22 AM
Quote:
Stay away from ATS
Unless u want problems [duhhh]
1 guy went through 5 trannys:
"I am having some SERIOUS problems with ATS. Has anyone else had the same issues that I have had. Keep in mind this happened with an 2006 2WD 48re no mods!
Trans 1. TC went out metal in pan(chunks)
Trans 2. Valve body replacement and washers in the tail shaft metal in pan
Trans 3. Loose shifting and lots of metal chunks in the pan
Trans 4. Metal in pan, lots of out of pocket shop visits and TC went out
Trans 5. Recieved trans 5 with bad sensors installed had to replace them as well as the sensor in the tail shaft and then broke a 2 piece pressed billet input shaft.(non modded truck)...
Is this all normal for ATS???
Is it normal to call ATS and never get a response back???
Is it normal to get stuck with the bill at a shop they tell you to visit and tell you they will pay for it?
They have a great warranty but is that because they build a sub par trans and they know you will use the warranty?
I am putting my full story together along with the pictures of the metal in my pan and the different stuff that I had to deal with while being involved with ATS. I will need to go through at least 20 or 30 emails to see how many of them were unanswered as well as my phone call logs. I spent 6000 bucks to put an ATS tranny in my truck and as you can see from above it did not work out so great. I am not trying to bash anyone I am simply telling all of you to the best of my ability what I have been through in the last 32 months. I put over 130000 miles on my stock trans...How come I never got more than 25000 out of an ATS? Is this normal??? Please let me know what you all think. Let me know if it were you, what you folks would be doing in my shoes. I tried speaking with Clint Cannon the owner of ATS, but he soon started ignoring my emails. I have tried everything in my power to work out my situation with ATS but have'nt anywhere else to go. I had to eventually go to another builder whom I will keep under my hat so as to not think I am "plugging them" for this post..This was done because I submitted a phone call broke down on the side of the road and did not recieve one ounce of help in what I should do(they were ignoring my issue) for 4 days only after they were aware I was having another builder fix it... Any input would be great of any of the forum members dealings with ATS that have turned out this way. I hope I am in this boat alone but I am sure I got some company..
Thanks To All and stay tuned there will be a large thread with detailed descriptions and pictures coming soon of what I have been through in the last 32 months.
650HP-CTD 12-06-2010 01:24 PM
I've had good luck with Dave at Triad in Loveland.
Triad Power Systems
135 12th St SE # 2
Loveland, CO 80537-6326
(970) 663-5503
--Sk
Copyright 2017, DieselTruckResource.com
