codes agrivating......
long story short my truck is throwing codes,, p1750, p0107, p0643, p0108, p0069. i do not have any downloaders stock except intake and exhaust, two weeks ago i threw A code 0069 and took it to dealer they replaced intake sensor problem went away 100 miles later i get this crap.
all i did today was hook up a new egt guage but i didn't wire anything new just cut old wires and crimed new ones so just to make sure i unhooked the guage i put in and same thing i also shut the truck off on on about 10 times codes still there and I AM IN LIMP MODE. on top of that i leave for a 1000mile road trip with my trialer on tues. anyone have any advise way to fix anything?
It really seems like you have a short somewhere. Just glancing at the diagnostic testing in the service manual it seems like you have a wiring harness that is shorted to a ground and that is what is causing most of these codes. I would start checking your different ECM PCM plugs and using dielctical grease when you snap them back together. Then get those codes cleared. BullyDog, Edge, Smarty, and a few others have the ability to scan and clear codes.
Do you have access to anything that you can use to clear codes? Do you have access to a Service manual? Shoot me a PM and I might be able to post a copy of the service manual on my FTP server that you can access.
P0069-boost Key On Rationality
Possible Causes
OTHER DTC’S PRESENT
INLET AIR PRESSURE SENSOR
BOOST PRESSURE SENSOR
INTERMITTENT CONDITION
P0107-inlet Air Pressure Sensor Voltage Too Low
P0107-manifold Absolute Pressure Sensor Circuit Low
P0107-map Sensor Voltage Too Low
possible Causes
Other Dtc’s Present
Inlet Air Pressure Sensor
Inlet Air Sensor (k616) Signal Circuit Shorted To The (y502) Return Circuit
Inlet Air Pressure Sensor (k668) Supply Circuit Shorted To The Return Circuit
(k616) Signal Circuit Open
(k668) 5-volt Supply Circuit Open
(k616) Signal Circuit Shorted To Ground
(k668) 5-volt Supply Circuit Shorted To Ground
Ecm
Intermittent Condition
P0108-inlet Air Pressure Sensor Voltage Too High
P0108-manifold Absolute Pressure Sensor Circuit High
P0108–map Sensor Voltage Too High
possible Causes
Other Dtc’s Present
Inlet Air Pressure Sensor (k616) Signal Circuit Shorted To Voltage
Inlet Air Sensor (k668) 5-volt Supply Circuit Shorted To Voltage
(k616) Signal Circuit Shorted To (k668) 5-volt Supply
(k690) Return Circuit Open
Ecm
P0643-high Voltage At The #2 Sensor Supply Circuit
P0643-primary 5-volt Supply Circuit High
possible Causes
(f855) Primary 5-volt Supply Shorted To Battery Voltage
Pcm
Fan Clutch Assembly
(k668) 5-volt Shorted To Voltage
Ecm
P1750-transmission Throttle Valve Position Sensor Circuit High
possible Causes
(k312) Ttva Position Sensor Signal Circuit Short To Voltage
(k312) Ttva Position Sensor Signal Circuit Short To Another Circuit
(k900) Sensor Ground Circuit Open
Transmission Throttle Valve Actuator
Engine Control Module
Possible Causes
OTHER DTC’S PRESENT
possible Causes
Other Dtc’s Present
Ecm
possible Causes
Other Dtc’s Present
Ecm
possible Causes
Pcm
Fan Clutch Assembly
Ecm
possible Causes
Check out the sticky post up top of forum.Seems alot of guys have found shorts that cause numerous codes. My bet is that you are one of the many!
My 03 has wire loom over all of the problem spots.Thats the way it came from factory.I guess the 2004.5 and up did not from what I have read.
Hope I helped.
Hope I helped.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
