Mark this thread as Unsold
JL Audio Stealthbox center seat for 98-02 Dodge Ram
Used, great condition JL Audio Stealthbox with JL 12W3v3-2 Subwoofer. Replaces the stock seat base. Uses the stock seat base legs and side mounts for the arm rest/seat back.
$375 + shipping. Located in Las Vegas, NV. Email to ws6ta@***.net or call 702-324-4449 for more info.
Subwoofer Features:
One JL Audio 12W3v3-2 Subwoofer
Power Handling: RMS: 500 watts
Recommended power range: 150 - 500 watts RMS
Wired to a 2 ohm load
Mineral-filled polypropylene cone woofer
Nitrile-butadiene rubber surround
DMA-optimized, long linear excursion capability to virtually eliminate distortion and increase sound output
Vented reinforcement collar improves rigidity and stability of the cone, spider, and voice coil
Spider and lead wire assembly
Elevated frame cooling enhances power and sound quality
Floating Cone Attach Method allow the cone and surround to be aligned independently
Xmax: 13.0 mm
Sensitivity: 87.15 dB
Matching Amplifier: JL Audio JX500/1D
Authorized Internet Dealer
2 Year Manufacturer's Warranty
Enclosure Features:
For 1998-2001 Dodge Ram 1500 & 1998-2002 Dodge Ram 2500/3500 with 40/20/40 split front bench seat
Down-firing design
Sealed enclosure
Stealthbox® replaces the bottom part of the factory front center seat
Binding post terminals for secure and sturdy connection and installation
Stealthbox® must be covered using cover from the bottom part of the factory front center seat
Stealthbox® is not padded and therefore not as comfortable to sit on as the factory seat cushion
Will not fit '94-'97 or '03-Up Dodge Ram
Installation requires repositioning of seat belt sensor
OEM Color: All
Subwoofer Features:
Xmax: 13.0 mm
Enclosure Features:
Down-firing design
Sealed enclosure
OEM Color: All
plug ugly
0
09-08-2009 02:51 PM
