JL Audio Stealthbox center seat for 98-02 Dodge Ram
3 Attachment(s)
Used, great condition JL Audio Stealthbox with JL 12W3v3-2 Subwoofer. Replaces the stock seat base. Uses the stock seat base legs and side mounts for the arm rest/seat back.
$375 + shipping. Located in Las Vegas, NV. Email to ws6ta@cox.net or call 702-324-4449 for more info. Subwoofer Features: One JL Audio 12W3v3-2 Subwoofer Power Handling: RMS: 500 watts Recommended power range: 150 - 500 watts RMS Wired to a 2 ohm load Mineral-filled polypropylene cone woofer Nitrile-butadiene rubber surround DMA-optimized, long linear excursion capability to virtually eliminate distortion and increase sound output Vented reinforcement collar improves rigidity and stability of the cone, spider, and voice coil Spider and lead wire assembly Elevated frame cooling enhances power and sound quality Floating Cone Attach Method allow the cone and surround to be aligned independently Xmax: 13.0 mm Sensitivity: 87.15 dB Matching Amplifier: JL Audio JX500/1D Authorized Internet Dealer 2 Year Manufacturer's Warranty Enclosure Features: For 1998-2001 Dodge Ram 1500 & 1998-2002 Dodge Ram 2500/3500 with 40/20/40 split front bench seat Down-firing design Sealed enclosure Stealthbox® replaces the bottom part of the factory front center seat Binding post terminals for secure and sturdy connection and installation Stealthbox® must be covered using cover from the bottom part of the factory front center seat Stealthbox® is not padded and therefore not as comfortable to sit on as the factory seat cushion Will not fit '94-'97 or '03-Up Dodge Ram Installation requires repositioning of seat belt sensor OEM Color: All |
