Broken Rings!!!
Old Sep 27, 2009 | 09:37 PM
Brian Lent's Avatar
Broken Rings!!!
Well I had injectors changed, head redone, valves, guides springs and decked. I was told that they were due for service but not bad enough to cause a rough idle and white smoke. So I dropped the pan in the truck and pulled all 6 pistons. Found 2 broken rings on #6 (problem cylinder), one broke on #5, and one broke on #1. Got all new rings and got her buttoned back up. Put head back on with arp's and waiting on rockers from a second gen because I am not using the pos plastic ones we have.Two of them are broke too. Has anyone else had ring problems? What would be the cause? EGTS? Thanks in advance
Old Sep 27, 2009 | 10:27 PM
Raspy's Avatar
From: Smith Valley, NV (sometimes Redwood City, CA)
Ether is a good cause of that. And the ring lands might be damaged too. When the rings get a lot of side clearance, from damaged pistons due to ether usage, they can break. Be sure to check the ring side clearance or you might be back in there soon.
Another cause is re-ringing an engine without removing the ridge at the top of the cylinder. The upper new square edge of the ring hits the ridge and is forced down. It can break the ring or damage the ring lands and then the ring has too much side clearance and can break.
Old Sep 27, 2009 | 10:38 PM
bobinyelm's Avatar
Just curious,
Sounds like you did the work yourself-
How much did the rings and new gaskets set you back?
You say you had it decked (the block), or did they just machine the head?
Were your pistons OK (no broken lands?)?
How many miles on your engine, and did you have a noticeable ridge on the top of the bores?
Did you have a problem getting a hone down into the back bores?
Was it burning oil, or just pushing smoke and oil from the breather vent?
Thanks,
Bob
Old Sep 28, 2009 | 06:53 AM
Brian Lent's Avatar
Originally Posted by bobinyelm
Just curious,
Sounds like you did the work yourself- Me and my brother
How much did the rings and new gaskets set you back? The rings were 50 each set and with gaskets, connector tubes, and drain tube it was $600. Head was $600
You say you had it decked (the block), or did they just machine the head? Yeah the head because it was .006 out
Were your pistons OK (no broken lands?)? Pistons were fine, Very smalll dings on the lands but had them checked out and got the green light.
How many miles on your engine, and did you have a noticeable ridge on the top of the bores? 140k hard miles, small ridge but it honed out
Did you have a problem getting a hone down into the back bores? Not at all, went right in but did have trouble keeping the hone from catching the oilers at the bottom
Was it burning oil, or just pushing smoke and oil from the breather vent? It was using oil, blowing oil some too for a fewk. Shut the truck off at work and fired it back up for lunch and chugchug. Bottom ring must have let go on start up.
Thanks,
Bob
Got it all, Thanks
Old Sep 29, 2009 | 12:30 AM
han solo's Avatar
Dirt also breaks rings.
Old Oct 18, 2009 | 06:25 AM
nwflyoda's Avatar
a good friend on mine is going to have to rebuild his 06. i believe he has a lot of blow by (coming out of the vent tube at the valve cover) and he goes threw about a gallon of oil every 3k miles. i wonder if we can just rebuild/rering the motor in the truck like you did.
Old Oct 18, 2009 | 08:43 AM
Brian Lent's Avatar
Yeah, it is definatley doable. I am not a mechanic but just had some experience working on my chevelle growing up. We just pulled the head, Loosened one motor mount and lift the engine enough to get to the pan. As long as you have some extra hands and the tools it's not that bad. Dirty but not bad.
Old Oct 19, 2009 | 01:45 AM
nwflyoda's Avatar
we have a bad feeling though that the cylinder walls are scroned from the amount of blow by he has. it still pulls fine though. we noitced after he bought the truck that the air filter got sucked up and dirt was getting past the filter into the turbo and what not.
Old Oct 19, 2009 | 06:34 AM
Brian Lent's Avatar
Mine had one small scratch in 5 and 6. nothing you could grab with a fingernail so I just honed it with a 220 stone real good. I would pull the head and have a look before you drop the pan. If it's not to bad then just do it right there, If it is well there is a little more work to be done. Just get a manual so that you have all the right torque specs. It's nothing but bolts.
Old Oct 19, 2009 | 09:50 AM
northernwheeler's Avatar
I had my truck in at the dealership a little while back, and got talking with the diesel mech. He told me that he had seen a few trucks come in with broken rings now, mostly the 04.5 and up. Said there was no rhyme or reason to it, some low miles, some high miles, some pulled heavy, others didn't. But he said he had fixed a few already. Maybe a design flaw?? I don't know, but I am seeing more posts about this kind of thing, there is a guy on cumminsforum going through this too.
ahire
13
Oct 17, 2008 12:50 PM
BigErksG2
Sep 25, 2008 06:43 PM
12VRoush
Oct 15, 2007 08:00 PM
1320
Mar 8, 2005 08:56 PM
