What is the "12 valve" of big rig engines?
Rugged, reliable, bulletproof, easy to turn up and bad as hell? So what is the baddest big rig engine out there? While we are at it, what do you guys think is the best trans?
3408 cat for power. Easy to crank and unbelievable power.course it was twin turbo.could drive with traffic at 140k pounds over the passes. trans idk, they are mostly pretty good so it's a hard call. ran a 10 and a 4 behind the 3408 never had a prob pullin 9 axles of lowboy
Don't know much about them, but Cummins made a KTA engine that were 1150 cu.in and could be made to make up to 2000 HP. It was a 6 cylinder, each cylinder had its own head. There were trucks that came with this engine. There was also an engine(Cummins V-12) that was two 855 cu. in cast together, I have never seen one, just read about them.
I worked on one of those cummins v12 engines in a genset last week. it was a 1976 model year. Kicking myself now for not getting a whole shot of it, but was documenting the water leaks at the time this particular big ol beast is natural gas powered, naturally aspirated, water cooled exhaust manifolds.
Thriving on neglect goes to N-14. They just don't seem to die. I read somewhere that no bottom end in a class eight truck was as stout. Owner of Pittsburg Power, I believe.
Ive always wondered the same. Id like to get a tractor and play with it; maybe when I strike it rich.
All (well most) of our equipment at work runs Cummins V12s. The older stuff was, then they switched to CATs, but I guess theyve had issues and the newer stuff is back running Cummins. CATs wont start in the cold, but the Cummins' fires up EVERY time. This is oilfield pumping equipment
Dt466
I have to second the DT466. All of our company trucks are beat on day in and day out and never miss a lick. Not the most powerful engine but dead reliable.
They do much better when they have more fuel. One of these days I'll get around to putting a 466 in a pickup, but that's another thread & another day.
They must be able to fix that since that has to be one of the most used powerplants in the Diesel tractor pulls. I was in Tomah WI for the NTPA pulls this weekend and saw a whole bunch of them making 1500+ HP! I wish I would have brought the camera, One of them had a 12 cyl. P-pump on it and was using what I think were injectors that would fire twice per comp stroke! It was making somewhere near 180psi and had a whole lot of H2O injection! I want one so bad I can taste it!
DS79
DS79
