New clutch time in my T800
while I had my KW in the shop this spring I ran out to the end of the of adjustment on my clutch, now after hauling silage, bales and cattle this spring summer and fall its now time to do a new clutch, any recommendations as to clutch material, self or manual adjusted? cast or stamped?
As a farm truck it will have a rough life per mile, lots of loaded starts in soft fields, silage pits, needs to be rated at 1850+ ft lbs after that I'm pretty "clutch dumb" so any help or advise would be greatly appreciated
i'm assuming its an eaton, but youll have to find what size clutch you need, im assuming its a 15" clutch but I found this little chart that that should help you kind of determine exactly what youll need. and as far as the adjustment i'm just the kind of person if I can do it myself I know its right and its just one less thing to go wrong. but I guess its just a personal preference.
http://www.roadranger.com/rr/Product..._343622#tabs-2
Derek Crowl
08-20-2013 10:43 PM
ratat98
06-29-2006 02:55 PM
Mule Skinner
01-09-2004 08:36 PM
