-   Big Rigs (https://www.dieseltruckresource.com/forums/big-rigs-169/)
-   -   International F2554 vs F2574 (https://www.dieseltruckresource.com/forums/big-rigs-169/international-f2554-vs-f2574-295981/)
csramsey640 Oct 7, 2011 10:43 PM
Does anyone know the difference between these models? Both are twin screw tractors with the same big cam engines. Same years, 1982 Thanks
Hvytrkmech Oct 11, 2011 09:09 AM
The only differences would be in the chassis spec, heavier axles, bigger brakes etc. Absolutely no difference in the cabs. Why do you ask?
csramsey640 Oct 12, 2011 10:14 AM
I am looking at purchasing one of these trucks,power trains identical. I did notice the 2574 has dual power steering boxes, and I do not believe the 2554 does. Thanks for the heads up.
Hvytrkmech Oct 12, 2011 11:27 AM
Dual steering box's means double or triple frame chassis which translates into worked real hard all its life.
Good luck either way.
csramsey640 Oct 12, 2011 10:02 PM
While Im at it, maybe you can shed some light on another subject. Both of these trucks are located about 800 miles away, have 5/4 trannies with "underdrive" and big cam 400hps. I understand the importance of oil testing, but does it really help on a 1 shot deal, or is it used more as a long term marker to check wear levels, etc over the course of many oil changes? I need the truck mainly for offroad use, so I want something built tough, and dont mind spending 10-15k to bring one up to good service.
In my opinion, and please correct me if Im wrong. I am setting a $40,000 budget. I can find one of the late 80's mentioned trucks for the 15-17k range. This unit will also stay primarily in state, so it will not be crossing the country. My first thought is to purchase in the 15-25k range, and have between 15-25k available to invest in the truck, rather than spend 40k on a truck, and find out it needs a clutch, tranny, etc and im then over budget to make it sound.
I also plan to run the truck almost daily pulling my dozers in a 4-5 hour radius.
This will be the first truck I have purchased on my own. I knew the history of my current truck, and didnt need to check it over( it was my dads and I drove it full time) but I will admit Im very green when it comes to purchasing an unknown truck and what to look for other than the obvious leaks, blow by, vibrations, etc. I have some experience shifting a 5 and 4, but not servicing or checking them.
NE frmhnd Nov 16, 2011 08:55 PM
If you take a tape measure you will probably find that the axle is set back farther on one, or the bumper-to-back-of-cab (BBC) measurement is different.
