Detroit 12.7 derating
I am having problems with the series 60 in our 98 Peterbilt. I seems like its being derated for some reason but a haven't been able to figure out what and never have the time to get it to the mechanic we use. A month or so ago I was in an ice storm with a heavy load and the grill was getting covered with ice and the motor warmed up just enough to make the engine fan come on. Anyways, while it was running warm, it ran perfect. Had all kinds of power like it should. BTW, it is a fairly strong 12.7, started life as a 470 motor but has put down 478 at the rear wheels. Anyways, my question is what sensors could go bad that could derate the motor. I have already replaced the boost sensor, fuel temp sensor, and the intake air temp sensor. I am sure that the is something dumb, but I just can't seem to figure it out. Thanks for any help.
I would check the air filter for icing and change out both fuel filters. I cut my ff maintenance in half during the winter months.
It is a little more serious than maintenance issues, but thanks anyways. It has been doing this for nearly a year and has steadly gotten worse. Didn't really notice it to someone else drove it that was use to the truck but had not drove it for a while said something.
get hooked up to DDDL to it what codes are logged? or can you cycle the flash codes? I can tell you what the flash codes are. if it is actually derating DDDL will show you the logged derate and why. don't throw parts at it until after you scan it with DDDL.
Have you had your wiring checked for your injectors from the ecm? Bad and long known issue with the 60's. The wiring loom wears holes in the wire's. Causing miss firing as well as codes. Have it checked out.;)
very true, thats why I said gotta pull codes 1st. no question there. in a '98 you have a DDEC IV the 30 pin harness pointing to the front of the truck off the ECM is the sensor harness. the grey and black 5 pin on the front side are the injector/jake harness. the rear of the ECM facing the truck. 30 pin is the vehicle interface harness. the big 5 pin at the top rear is the power harness. the 6 pin in the middle back is the communications harness.
pull back 18" of loom on each harness and inspect for rub throughs. when you pull codes if you have Injector Response Time - Too Long on a cylinder or multiple cylinders. its generally a harness problem, high resistance in the circuit. If you have Injector Response Time - Too Short its generally an injector issue. not harness. heres the flash code list for the DDEC IV 10 Intermittent Fault 10.1 Intermittent Code or a Symptom and No Codes 10.2 Engine Cranks But Will Not Start 10.3 Erratic Performance and No Codes 10.4 Check Engine Light and Stop Engine Light Fault 10.5 No Data to Diagnostic Data Reader 10.6 Diagnostic Request Switch Inoperative 10.7 Cruise Control Inoperative 10.8 Fan Operational Concern (On/Off Type) 10.9 Fan Operational Concern (Variable Speed Type) 10.10 Engine Brake Inoperative 10.11 Miscellaneous Digital Input Fault 10.12 Miscellaneous Digital Output Fault 10.13 Fire Truck Pressure Governor Fault 10.14 Optimized Idle Feature Does Not Function 10.15 Transmission Interface Fault 10.16 Exhaust Gas Recirculation System (EGR-1) – Fault, Series 50 Engine 10.17 Maintenance Alert System 10.18 Exhaust Gas Recirculation System Basic Checks for Series 60 Engines 11 Flash Code 11 - VSG Low 12 Flash Code 12 - VSG High 13 Flash Code 13 - CLS Voltage Low 14 Flash Code 14 - Temp Sensor High 15 Flash Code 15 - Temp Sensor Low 16 Flash Code 16 - CLS Voltage High 17 Flash Code 17 - Throttle Valve High: Relative Humidity Sensor High 18 Flash Code 18 - Throttle Valve Low; Relative Humidity Sensor Low 21 Flash Code 21 - TPS High 22 Flash Code 22 - TPS Low 23 Flash Code 23 - Fuel Temp Sensor High 24 Flash Code 24 - Fuel Temp Sensor Low 26 Flash Code 26 - Auxiliary Input Active 27 Flash Code 27 - Air Temp Sensor High 28 Flash Code 28 - Air Temp Sensor Low 29 Flash Code 29 – TCI / TCO Temperature Low 29.1 Description of Flash Code 29 29.2 SAE J1587 Equivalent Code for Flash Code 29 29.3 Troubleshooting Flash Code 29 30 Flash Code 30 30.1 Description of Flash Code 30 31 Flash Code 31 - Engine Brake Fault Code or EGR / PWM Fault 31.1 Description of Flash Code 31 31.2 SAE J1587 Equivalent Code for Flash Code 31.3 Troubleshooting Flash Code 31 32 Flash Code 32 - CEL / SEL Fault 32.1 Description of Flash Code 32 32.2 SAE J1587 Equivalent Code for Flash Code 32 32.3 Troubleshooting Flash Code 32 33 Flash Code 33 - TBS High 33.1 Description of Flash Code 33 33.2 SAE J1587 Equivalent Code for Flash Code 33 33.3 Troubleshooting Flash Code 33 34 Flash Code 34 - TBS Low 34.1 Description of Flash Code 34 34.2 SAE J1587 Equivalent Code for Flash Code 34 34.3 Troubleshooting Flash Code 34 35 Flash Code 35 - OPS High 35.1 Description of Flash Code 35 35.2 SAE J1587 Equivalent Code for Flash Code 35 35.3 Troubleshooting Flash Code 35 36 Flash Code 36 - OPS Low 36.1 Description of Flash Code 36 36.2 SAE J1587 Equivalent Code for Flash Code 36 36.3 Troubleshooting Flash Code 36 37 Flash Code 37 - FPS / FRS Voltage High 37.1 Description of Flash Code 37 37.2 SAE J1587 Equivalent Code for Flash Code 37 37.3 Troubleshooting Flash Code 37 38 Flash Code 38 - FPS / FRS Voltage Low 38.1 Description of Flash Code 38 38.2 SAE J1587 Equivalent Code for Flash Code 38 38.3 Troubleshooting Flash Code 38 39 Flash Code 39 – EGR Valve / VNT Vane Fault 39.1 Description of Flash Code 39 39.2 SAE J1587 Equivalent Code for Flash Code 39 39.3 Troubleshooting Flash Code 39 40 Flash Code 40 40.1 Description of Flash Code 40 41 Flash Code 41 - Too Many SRS 41.1 Description of Flash Code 41 41.2 SAE J1587 Equivalent Code for Flash Code 41 41.3 Troubleshooting Flash Code 41 42 Flash Code 42 - Too Few SRS 42.1 Description of Flash Code 42 42.2 SAE J1587 Equivalent Code for Flash Code 42 42.3 Troubleshooting Flash Code 42 43 Flash Code 43 - Coolant Level Low 43.1 Description of Flash Code 43 43.2 SAE J1587 Equivalent Code for Flash Code 43 43.3 Troubleshooting Flash Code 43 44 Flash Code 44 - Temp High 44.1 Description of Flash Code 44 44.2 SAE J1587 Equivalent Code for Flash Code 44 44.3 Troubleshooting Flash Code 44 45 Flash Code 45 - Oil Pressure Low 45.1 Description of Flash Code 45 45.2 SAE J1587 Equivalent Code for Flash Code 45 45.3 Troubleshooting Flash Code 45 46 Flash Code 46 - Battery Voltage Low 46.1 Description of Flash Code 46 46.2 SAE J1587 Equivalent Code for Flash Code 46 46.3 Troubleshooting Flash Code 46 47 Flash Code 47 - Air / Fuel Pressure High 47.1 Description of Flash Code 47 47.2 SAE J1587 Equivalent Code for Flash Code 47 47.3 Troubleshooting Flash Code 47 48 Flash Code 48 - Air / Fuel / EGR Pressure Low or EGR / TCI / TCO Temperature Low 48.1 Description of Flash Code 48 48.2 SAE J1587 Equivalent Code for Flash Code 48 48.3 Troubleshooting Flash Code 48 49 Flash Code 49 – TCO or TCI Temperature High 49.1 Description of Flash Code 49 49.2 SAE J1587 Equivalent Code for Flash Code 49 49.3 Troubleshooting Flash Code 49 50 Flash Code 50 50.1 Description of Flash Code 50 51 Flash Code 51 – TCO or TCI Temperature Circuit Failed High 51.1 Description of Flash Code 51 51.2 SAE J1587 Equivalent Code for Flash Code 51 51.3 Troubleshooting Flash Code 51 52 Flash Code 52 - ECM Fault 52.1 Description of Flash Code 52 52.2 SAE J1587 Equivalent Code for Flash Code 52 52.3 Troubleshooting Flash Code 52 53 Flash Code 53 - ECM Memory Fault 53.1 Description of Flash Code 53 53.2 SAE J1587 Equivalent Code for Flash Code 53 53.3 Troubleshooting Flash Code 53 54 Flash Code 54 - VSS Fault 54.1 Description of Flash Code 54 54.2 SAE J1587 Equivalent Code for Flash Code 54 54.3 Troubleshooting Flash Code 54 55 Flash Code 55 - J1939 Data Link Fault 55.1 Description of Flash Code 55 55.2 SAE J1587 Equivalent Code for Flash Code 55 55.3 Troubleshooting Flash Code 55 56 Flash Code 56 - J1587 Data Link Fault 56.1 Description of Flash Code 56 56.2 SAE J1587 Equivalent Code for Flash Code 56 56.3 Troubleshooting Flash Code 56 57 Flash Code 57 - J1922 Data Link Fault 57.1 Description of Flash Code 57 57.2 SAE J1587 Equivalent Code for Flash Code 57 57.3 Troubleshooting Flash Code 57 58 Flash Code 58 58.1 Description of Flash Code 58 58.2 SAE J1587 Equivalent Code for Flash Code 58 59 Flash Code 59 59.1 Description of Flash Code 59 60 Flash Code 60 60.1 Description of Flash Code 60 61 Flash Code 61 - Injector Response Long 61.1 Description of Flash Code 61 61.2 SAE J1587 Equivalent Code for Flash Code 61 61.3 Troubleshooting Flash Code 61 62 Flash Code 62 - Output Fault 62.1 Description of Flash Code 62 62.2 SAE J1587 Equivalent Code for Flash Code 62 62.3 Troubleshooting Flash Code 62 63 Flash Code 63 - PWM Fault 63.1 Description of Flash Code 63 63.2 SAE J1587 Equivalent Code for Flash Code 63 63.3 Troubleshooting Flash Code 63 64 Flash Code 64 — Turbo Speed Sensor Fault 64.1 Description of Flash Code 64 64.2 SAE J1587 Equivalent Code for Flash Code 64 64.3 Troubleshooting Flash Code 64 65 Flash Code 65 - Throttle Valve Fault, Air Filter Restriction Input Voltage Low 65.1 Description of Flash Code 65 65.2 SAE J1587 Equivalent Code for Flash Code 65 65.3 Troubleshooting Flash Code 65 65.4 Air Filter Restriction Sensor 66 Flash Code 66 - Knock Sensor Fault 66.1 Description of Flash Code 66 66.2 SAE J1587 Equivalent Code for Flash Code 66 66.3 Troubleshooting Flash Code 66 67 Flash Code 67 - Map Sensor Fault 67.1 Description of Flash Code 67 67.2 SAE J1587 Equivalent Code for Flash Code 67 67.3 Troubleshooting Flash Code 67 67.4 Map Input Voltage High 67.5 Map Input Voltage Low 68 Flash Code 68 - Idle Validation Fault 68.1 Description of Flash Code 68 68.2 SAE J1587 Equivalent Code for Flash Code 68 68.3 Troubleshooting Flash Code 68 69 Flash Code 69 69.1 Description of Flash Code 69 70 Flash Code 70 70.1 Description of Flash Code 70 71 Flash Code 71 - Injector Response Short 71.1 Description of Flash Code 71 71.2 SAE J1587 Equivalent Code for Flash Code 71 71.3 Troubleshooting Flash Code 71 72 Flash Code 72 - Vehicle Overspeed 72.1 Description of Flash Code 72 72.2 SAE J1587 Equivalent Code for Flash Code 72 72.3 Troubleshooting Flash Code 72 73 Flash Code 73 — ESS Fault 73.1 Description of Flash Code 73 73.2 SAE J1587 Equivalent Code for Flash Code 73 73.3 Troubleshooting Flash Code 73 74 Flash Code 74 — OI Safety Loop 74.1 Description of Flash Code 74 74.2 SAE J1587 Equivalent Code for Flash Code 74 74.3 Troubleshooting Flash Code 74 75 Flash Code 75 - Battery Volt High 75.1 Description of Flash Code 75 75.2 SAE J1587 Equivalent Code for Flash Code 75 75.3 Troubleshooting Flash Code 75 76 Flash Code 76 - Engine Overspeed / Brake 76.1 Description of Flash Code 76 76.2 SAE J1587 Equivalent Code for Flash Code 76 76.3 Troubleshooting Flash Code 76 77 Flash Code 77 - Exhaust Back Pressure Fault and Several Information Codes 77.1 Description of Flash Code 77 77.2 SAE J1587 Equivalent Code for Flash Code 77 77.3 Troubleshooting Flash Code 77 78 Flash Code 78 — Cruise Control / Adaptive Cruise Control 78.1 Description of Flash Code 78 78.2 SAE J1587 Equivalent Code for Flash Code 78 78.3 Troubleshooting Flash Code 78 79 Flash Code 79 79.1 Description of Flash Code 79 80 Flash Code 80 80.1 Description of Flash Code 80 81 Flash Code 81 – Oil Level, Exhaust Temp, EGR Temp or EGR Delta-Pressure, Circuit Failed High 81.1 Description of Flash Code 81 81.2 SAE J1587 Equivalent Code for Flash Code 81 81.3 Troubleshooting Flash Code 81 81.4 Troubleshoot Maintenance Alert System 81.5 Troubleshoot Exhaust Gas Temperature 82 Flash Code 82 – Oil Level, Exhaust Temp, EGR Temp or EGR Delta-Pressure, Circuit Failed Low 82.1 Description of Flash Code 82 82.2 SAE J1587 Equivalent Code for Flash Code 82 82.3 Troubleshooting Flash Code 82 82.4 Troubleshooting Maintenance Alert System 82.5 Troubleshoot Exhaust Gas Temperature 83 Flash Code 83 – EGR Temp, EGR Delta-Pressure, Exhaust Temp, or External Pump Pressure High 85 Flash Code 85 - Engine Overspeed 86 Flash Code 86 - PGS Sensor High 87 Flash Code 87 - PGS Sensor Low |
Hey thanks for the info on the wiring harness. I will look at that when I get a chance. The truck does have a pro driver display in it so it atleast shows some of the problems but I am guessing that it doesn't pick up everything. Is that correct? There isn't any way it will show all the codes is there?
Thank you very much for the help. |
No problem..And you are more than welcomed. Thats what we are here for. Skin the harness back and look at your wiring. "CODES" are a general guide line. From DD..We chased our tail on an FL just to find out it was a bad ground on the cab and chassis. It would throw all the "CODES" that were listed above. The factory guide line code's didn't help us at all. After replacing four turbo's(that were out of spec from DD) as well as a complete ECM an engine wiring harness. Series 60's are known for bad injector wiring.
yes you have to know how to interpret codes. thats for sure. series 60 has been my bread and butter for the last 2 years. we don't deal with chassis issues thank god. just engines.
That was the "problem" it would throw code's for a bad turbo and ended up being a bad ground on the chassis wiring..
what other codes did you get along with that? see what I'm saying is a bunch or a few seeming unrelated codes or codes that arise and don't have a problem with the circuit would point me to grounding or harness issues. poor ECM grounding on DDEC will do some goofy things. what code was it anyways? and what DDEC was it? theres harness to the Vpod control then air to the turbo on ddec IV and V and ddec VI has VGT with harness to the actuator on the turbo/
Originally Posted by 1-5-3-6-2-4
(Post 2684392)
I don't mean to pry by anymeans, I'm just curious about things, that are interesting like that. and i remember how big a deal the actuator replacement/ adjustment feature was when DD introduced it for ddec V. I did an actuator replacement on friday actually.
(Post 2685868)
Where is the computer ground at? Does it go through the wiring harness or is it one of the bolts that hold it to the motor?
| All times are GMT -5. The time now is 03:26 AM. |
