95 C8.3 Cummins Info Needed
Hey Guys
Looking at a RV Hauler to replace my 06 (which runs great) as we are probably going to get another 5th wheel that is about 4-5K heavier than what I currently have. The Engine is as shown in the title. It has an Allison 3160P Tranny. (6Sp) Using the Build sheet Serial for the engine, Cummins told be it was 275HP What I need to know is; What is the Torque Rating ? What is the Max HP for that Block Series if anyone knowns for that year? Its a 12 Valve just like my old 96. Same Inj Pump More less. Anyone know what injectors would be needed to get her up a little above 300 hp? Thanks for the help. Dave |
Originally Posted by CoastalDav
(Post 3299209)
Hey Guys
Looking at a RV Hauler to replace my 06 (which runs great) as we are probably going to get another 5th wheel that is about 4-5K heavier than what I currently have. The Engine is as shown in the title. It has an Allison 3160P Tranny. (6Sp) Using the Build sheet Serial for the engine, Cummins told be it was 275HP What I need to know is; What is the Torque Rating ? What is the Max HP for that Block Series if anyone knows for that year? Its a 12 Valve just like my old 96. Same Inj Pump More less. Anyone know what injectors would be needed to get her up a little above 300 hp? Thanks for the help. Dave There's injectors available up to 480hp, but you'll be over 300 just from sliding the fuel plate forward. |
Thanks for the reply. Been a while since I posted question.
Dave |
(Post 3304848)
Dave |
