Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
M-11 Help Needed
Old 07-17-2012, 07:07 PM
d22019's Avatar
M-11 Help Needed
What would cause an m-11 to just start billowing black smoke and miss at idle and through the whole rpm range?
Old 07-18-2012, 12:42 AM
pind's Avatar
A really bad injector. Or more than one.
It does happen from time to time.
I was working on a kenworth the other day, that has a backfiring problem. Well, turns out it had a couple of injectors hanging hard enough to load the exhaust with fuel residue, and occasionally it would fire off. Loud, like a 10 gauge shotgun.
It exhibited the same symptoms prior to the backfiring beginning.
Old 07-19-2012, 08:57 AM
d22019's Avatar
My friend replaced all the injectors and the cam sensor and it still does the same thing. Next step would be ecm replacement?
Old 07-19-2012, 10:44 AM
dieselfreak21's Avatar
I would see if there is a software update or code present. My dad's had a slight miss occassionaly and they did and ecm update and problem went away. No black smoke on his.
Old 07-19-2012, 03:53 PM
Hvytrkmech's Avatar
What are the boost pressures? Check for bad CAC, was a new fuel pump put on recently?
Old 07-21-2012, 02:52 PM
d22019's Avatar
Would low coolant or a bad coolant sensor cause this? The ecm tested good at cummins but it had a coolant code in it. The owner said it would start missing going around corners which makes me think its low on coolant.
Old 07-26-2012, 08:03 AM
Hvytrkmech's Avatar
Is it actually missing as in dropping a cylinder or is it derating from a perceived lack of coolant?
Old 09-26-2012, 09:35 PM
d22019's Avatar
Update. Turned out one of the new injectors was faulty. Runs great now. Its still using coolant last I heard but runs good. The slowness is due to the programming. Its rated at 300hp and pulls like my 12v but it does the job.
royta
08-30-2004 12:41 PM
GMScott
08-12-2003 12:36 AM
damon_achey
03-24-2003 05:30 PM
Hummin Cummins
03-24-2003 07:41 AM
Quick Reply: M-11 Help Needed
