trailer modifications
Some of you have seen my car hauler, it is a tilt deck with a hydraulic ram that eases the deck down when I drive on. I want to modify this so that I can lock it in the up posistion, what do I need to do to make this happen.
The reason I want to do this, is that if I have to load my truck dead and you are towing it on, it will start to tilt the deck down before my truck is on there
Do you mean lock it in the tilted position, as you would have it when you are loading. If that's what you want, just put a valve in the lines on the cylinder so it can't bleed down. You can add a ball valve, just on and off, and it won't effect the tilt unless it's in the closed position.
I dont think that there are any lines on the cylnder,, not that I can remember,, I will look at that when I unload my trailer later this week,,, so I could just put a ball valve in somewheres and some line and that will do the job?
I use something similar on my loader to lock out the boom when you raise it. The only problem is if the boom drifts/sinks against the boom lock you can't remove it without being able to raise the boom just a little.
PistolWhipt
Nov 7, 2002 05:27 PM
