so cats out of the bag
Old Nov 7, 2010 | 03:16 PM
1-5-3-6-2-4's Avatar
Originally Posted by Danderson
I too love the Ford bodies and styling. The cab is roomy and easier to get in/out of then my '07 CTD. The other plus is the new coil sprung suspension. It knocked 5.5' off the turning radius in every configuration. There's an older F-250 around here with a 12v in it. NICE!
and when I bag the D60 thats in it and stick the super60 in, the 1550 joints in the axle shafts knock the turning radius down way more than the regular 60. and I will slide the 12v in it when I have to.
Old Nov 7, 2010 | 03:21 PM
Hvytrkmech's Avatar
The cab is nice for sure, I miss the extra room of my F350, but overall I like my Dodge better. probably cause I have the fold flat floor and that was not available in the Ford in 03. I put an Edge juice platinum on it then kept blowing rear end clutch packs.
Originally Posted by rbryanm
I recently traded my 04 SD in on an 06 CTD. The only problem with the 5R100 is that it has a tendency to hunt for gear in Tow/Haul. Stout trans though.
Congrats
I find the opposite of that in all our service trucks. they're all superduties. and weigh in around 12-14k in tow haul they are rock steady and hold gears way longer. and the engine braking is really good in tow haul too.
Old Nov 7, 2010 | 03:24 PM
this 06 has a sort of fold up rear seats and then theres a steel shelf deal you flip out from under the seats to have a wide flat steel "floor" for stuff.
....and I will scab both diffs in from the big truck at some point. so I'ma not worried about hurting it. the rear D110 has a detroit truetrac in it already. no clutches. but I'll have to figure out the single wheel aspect of it first./
and the super60 turning radius is supernice with the 1550 axle shaft joints, and the fact that the balljoints are easily twice as big sure helps piece of mind too.
Old Nov 8, 2010 | 08:27 AM
Mike Holmen's Avatar
The Guru
Originally Posted by Dr. Evil
Is that the same tranny the V-10 has? Any idea?
Here is a gaser/diesel conversion info link. I think that the transmission/converter/driveline is different.
http://www.fordcummins.com/99-ford-c...-overview.html
Old Nov 8, 2010 | 10:31 AM
Dr. Evil's Avatar
thanks mike.
Old Nov 13, 2010 | 03:06 PM
rage_blue's Avatar
Looks like a fun project. I'd like to do 12 valve swap, but I don't have a shop at home and no one wants to pay full shop rate at work to have it done.
Lonepine78
Sep 25, 2013 10:57 AM
GO 4LO
Aug 10, 2007 09:19 AM
dodgediesel
May 15, 2007 12:07 PM
PZM123
Feb 5, 2007 06:01 PM
Push Rod
Oct 7, 2002 12:27 AM
