-   ABDTR #5 (https://www.dieseltruckresource.com/forums/abdtr-5-123/)
-   -   Shop thread (https://www.dieseltruckresource.com/forums/abdtr-5-123/shop-thread-306917/)
morkable Oct 6, 2012 10:48 PM
Shop thread
I thought maybe I would start a new one, so it would be easier to figure stuff out.
Now, here is my dilema, I am still on the fence as to stick build or get a futresteel (or the like) building... to be honest the biggest problem I am seeing with the steel (or possible percieved problem) is the insulation deal,, do you think a person can insulate them to an acceptable level for our climate?
Lary Ellis (Top) Oct 7, 2012 12:24 AM
Have you looked into a pole barn on a floating slab? That is the way I think I am going. No matter which way you go, you can insulate it as necessary.
morkable Oct 7, 2012 10:16 AM
To be honest I havent really even thought about a pole barn,, what would the advantage/disadvantage be?
One thing about where I live insulation is very very important
Busboy Oct 7, 2012 12:05 PM
What I described to you in my first post on the last thread was a pole barn, I just called it a post and beam because a pole barn often uses round old telephone poles, a 6X6 pressure treated is much nicer to work with. The roof is insulated with blown in or batts and the walls are strapped horizontally on either side of the post to leave a 6 inch cavity that is filled with batts. Don't use OSB for the ceiling inside it warps all over the place.
Drill the holes and set the posts. pour the floor then build the roof in sections on the floor and crane into position, brace and finish the strapping for the roof and sheet with cut to length sheets. They really are so simple and cheap to build. We have mostly used the cannonball track as it is far superior, we have run the doors down inside one wall, straight across the front and across the front outside the building sidewalls, that one gets tricky in high wind. You can also use a bifold door hangar style. For the doors we used 1 1/2 inch 100 wall for a frame and use the metal sheeting for strength and rigidity, rubber belting across the bottom, spray foam or glue sheet insulation to the inside.
morkable Oct 10, 2012 11:47 PM
I talked to a fellow from Future Steel today,, they have a 40w x 21h x 56l shop that I could get for 25k delivered.. and it would be 8600 for r 13 insulation or 12300 for r20 insulation. This is basically a 3 wall system, I would still have to make an end wall with my overhead doors etc. What do you guys think?
winkdemon Oct 12, 2012 11:23 AM
thats a pretty good price . my buddy in ontario has one of those buildings , there easy to put up and seem to last. we did it close to 10 years ago still looks good
morkable Oct 12, 2012 01:24 PM
Rob, did he get the insulation from them?
winkdemon Oct 13, 2012 06:08 PM
no we spray foamed the hole thing , then put plywood over the hole thing , and it has in floor heat
morkable Oct 13, 2012 07:00 PM
The guy phoned back today,, they are in a serious rush, he dropped the price to 20000. LOL,, seeing as i dont have the money right now, I cant wait to see what they will sell it for when I actually have the money.
Rob, do you know roughly how much that spray foam was?
Diesel Dave2 Oct 13, 2012 09:32 PM
When is the house warming party...Kevin.... :)
morkable Oct 13, 2012 10:33 PM
Well it will be a bit Dave,, we wont actually be moving in till next summer believe it or not
Dieselbuilder Oct 14, 2012 12:53 AM
A steel building is still going to be cold no matter what you do in that part of the neighborhood 2x6 wood frame will be the best
morkable Oct 14, 2012 09:56 AM
I did some calculating last night, and just using the normal prices off of the totem website, I can build a 40 x 60 x 16 shop up to the point of putting siding etc on for around 20 grand (not including concrete) That is with 2x6 walls. So I definately am going to go that direction. I cant see the reason to go steel if it is close to the same price as stick built.
Question, would you go with just a slab floor, or would you go with a 1 foot foundation wall and then pour the floor later?
Tate Oct 14, 2012 09:50 PM
You may want to check into codes for the county you are building in. I know Rockyview is worse than the cities for building codes and regs. I had to put a 4' deep foundation wall for my garage. Yours being twice the size and close to twice the height, I'd think they may require it, or possibly something engineered.
morkable Oct 14, 2012 11:02 PM
I will check into that Tate... but from what I have been told they are fairly lieniant there... but I will definately check into it before I build
