-   ABDTR #5 (https://www.dieseltruckresource.com/forums/abdtr-5-123/)
-   -   pistons coating ? (https://www.dieseltruckresource.com/forums/abdtr-5-123/pistons-coating-265082/)
winkdemon Mar 1, 2010 11:13 PM
pistons coating ?
were can i get a set of pistons in alberta ? any one now [coffee]
Tate Mar 2, 2010 01:34 AM
12v? I think you can get coated marines from Cummins.
Mike Holmen Mar 2, 2010 08:45 AM
They are going to be pricey, here in Alberta. Anybody know what kinda of coatings that they use on the pistons? Keep us posted on what you find buddy.
A Piston from Cummins and coated, wow, I wonder what thats worth.
winkdemon Mar 2, 2010 10:05 AM
well i wil phone my engine builder buddy in ontario see what he says
ccmckee Mar 2, 2010 10:15 AM
Regular pistons are $400 ea from cummins, i can just imagine what coated ones would be.
John_P Mar 2, 2010 10:18 AM
winkdemon:
Let me see if I can give you some info here.
Cummins does make a piston that is coated but I am pretty sure it is a marine piston. You can also send your pistons out to have the coating done.
Scheid Diesel has done my stock pistons before or they can order you coated pistons from Arias or Mahle. The coatings vary, but they are generally a high heat ceramic coating and IMO they hold up very well and do make the pistons last longer. You can contact Brad Ingram @ Scheid Diesel if you are interested. Here is his toll free number: 1-800-669-1934.
Hope this helps you some Sir.
John_P
winkdemon Mar 2, 2010 10:28 AM
great
thanks for the info
John_P Mar 2, 2010 11:34 AM
Originally Posted by winkdemon (Post 2714959)
great
thanks for the info
winkdemon:
You are very welcome Sir.
One other thing I would add is the price that DTR Member ccmckee gave you on the price of Cummins pistons is close, but if you shop aroung on-line you can find some better prices than that.
John_P
Mike Holmen Mar 2, 2010 12:02 PM
Rob, is it for a 12v, 24v or a common rail? I can probably find you 6 pistons for the same price as cummins parts would sell you two.
John P, How did they coat the piston? The top, bowl, skirt, inside?
John_P Mar 2, 2010 02:14 PM
Mike:
On the stock set of Cummins Pistons that Scheid Diesel had coated for me they coated the sides of the piston and down the skirt. Not inside though.
The Arias and Mahle Pistons are entirely coated, but they are forged pistons, not cast.
Hope that helps you some.
John_P
Mike Holmen Mar 2, 2010 04:32 PM
Thanks buddy, I'm just trying to figure out this stuff myself.
krh Mar 2, 2010 04:57 PM
alberta engine sells federal mogul pistons for a **** good price. If you have to resort to buying pistons and getting them coated
Tate Mar 2, 2010 07:33 PM
Talk to Snedge on comp-d. He is a Cummins partsman and supposedly has unbeatable prices.
winkdemon Mar 3, 2010 12:57 AM
well when i put my 12v back together i was thinking of coating the pistons ,, the but it depends on price , i no it does make a differents i had a set in a gas engine night and day differents
John_P Mar 3, 2010 03:26 PM
winkdemon:
I agree with you on the coating not only making a difference on the heat, but with the ones I had I also saw less wear on the sides of the pistons too.
