-   ABDTR #5 (https://www.dieseltruckresource.com/forums/abdtr-5-123/)
-   -   IC Boots? (https://www.dieseltruckresource.com/forums/abdtr-5-123/ic-boots-250144/)
ccmckee Aug 17, 2009 10:12 AM
IC Boots?
Do any of you Calgary area folks have a pair of boots for the intercooler that i could borrow for a day? I want to test the intercooler that was in my truck when i had the accident last year for leaks. It looks fine,with only a broken tab on the bottom and the right side tab broke off.Hopefully i can throw it back in.
Homestead Aug 17, 2009 12:28 PM
A couple of pieces of old inner tube (one with the valve stem attached) and a couple of hose clamps will get it done.
Doesn't take much in the way of psi to show a leak.
Jeff
ccmckee Aug 17, 2009 01:57 PM
That's a good idea Thanks Homestead.
Tate Aug 17, 2009 04:31 PM
I have my old ones at home. But I am in Edmonton. If you still need them when I come back, I'll bring them along when we set your timing.
1-5-3-6-2-4 Aug 17, 2009 06:14 PM
I have a set of stock CAC boots from an old engine you can use. no prob.
ccmckee Aug 18, 2009 07:48 AM
Thanks Luke and Tate i'll let you know i'm gonna try Homesteads idea first.
ccmckee Aug 23, 2009 05:20 PM
Just thought i'd let you know the inner tube idea worked perfectly, Jeff :cool:. I can throw my aftermarket intercooler back in , not one leak anywhere's.
Homestead Aug 23, 2009 06:42 PM
Glad it helped.
I've used this trick on rads, intercoolers, a few times and had great success. As long as it a lower pressure, it will work fine.
Jeff
