I cant win
Old Aug 12, 2009 | 11:44 PM
dodgediesel's Avatar
Will you be able to get one in time on warranty? Did you get it from NADP? If so, the last one that crapped out on me was warrantied overnight from E town to Red Deer by Craig at NADP...
Old Aug 12, 2009 | 11:52 PM
morkable's Avatar
It is over a year old. So no warranty as far as I know.
Old Aug 12, 2009 | 11:54 PM
Tate's Avatar
Did you put a 30A fuse in the fuse block for it? Its the front most block, closest to the engine. Was a 20A in it, neither of us had a 30 for it. Might have popped the fuse.
Old Aug 12, 2009 | 11:59 PM
Good idea Tate. They should all come with a 6 year warranty. Mine has a lifetime warranty because I got mine in the spring when they had that promo....
Old Aug 13, 2009 | 12:01 AM
Dr. Evil's Avatar
Hope you can get it under control Kevin...
Old Aug 13, 2009 | 12:03 AM
You should have no issues warranting it Kevin. You spent alot of money at that store!!!!!!
Old Aug 13, 2009 | 12:46 AM
morkable's Avatar
I wont be able to work on it anymore here,, we are off to Edmonton tomorrow,, so I will have to work on it there.. hopefully there are some of you guys around to lend me a hand,,(tools) LOL... try and get it figured out. I will buy some new filters there and see how that goes. I went to go and drain the tank, but I couldnt get the feed line off of the bottome cp3.
Old Aug 13, 2009 | 08:09 AM
What series is that FASS?? Is it the smaller filter 95 series or the larger filter 150 series?
Old Aug 13, 2009 | 08:15 AM
morkable's Avatar
Its the 150 150. Anyone know what the replacement filters are?
Old Aug 13, 2009 | 08:42 AM
Mike Holmen's Avatar
The Guru
Which filter you looking for? I just get mine fuel filter from NAPA and the water seperator from PDR or Peak. The fuel filter is a common filter. I found that the NAPA filter seems to give me higher supply pressure than the fass filter. My system is seven year old and still working fine. I never used a fuse on my set-up. I had the relay bad corrided earlier this year and the fass wouldn't get any power. I would just bypass the relay/fuse and see what you get.I ran mine just off two wires tied together for abit and some electrical tape. Things that you do when you stuck on the side of the road and its -35deg's and the truck doesn't want to run.
Old Aug 13, 2009 | 09:40 AM
morkable's Avatar
I am not sure who all is going to be in E-town tonight, but if you are, give me a call on my cell 780-215- 3479 I will be in the parking lot of the royal executive hotel in nisku working on this thing..
Old Aug 13, 2009 | 09:41 AM
morkable's Avatar
I would think that the water seperator filter should be ok??? I drained it and everything looked good coming out... or should I change it too
Old Aug 13, 2009 | 11:13 AM
roxxx's Avatar
Originally Posted by dvst8r
I prefer this style for motorsports http://hargettprecision.com/index.php?cpath=50 a little less spendy, and easier to work with.
Kinda off topic though, I hope that Kevin can get this thing running!
Wow nice good to know Thank you
Old Aug 13, 2009 | 11:31 AM
Dr. Evil's Avatar
Kevin, if you want to can stop by my place - I have more tools then youll need. A few parts stores are close as well.
Old Aug 13, 2009 | 12:09 PM
morkable's Avatar
I might take you up on that Shane.. not sure how late I will be there,, i will give you a shout.
