Garrett
My brother bought it - had no idea what he was buying...and I dont think he paid a lot for it.
He was putting it on his mustang
This is maybe the next step up for Kevin.
That is a Garrett (duh) BTV85.
The turbo OE number is 714322-0002.
The DD PN is the number on the tag in front of you.
the OE compressor wheel is a 448671-0019
the OE comp cover is a 706570-0002
The OE turbine wheel is a 448953-0003
The turbine housing is 441881-0037
Turbine wheel Inducer is 99.1, exducer 87.9 Comp wheel inducer is 74.7, comp wheel exducer is 102.3.
11 turbine wheel blades
hope that helps
hope that helps
Look, I may be jammed full of totally useless information, but all I know, is judging by the product tag, it would have been mounted on something pale green, that leaks.
Other than that, I am of no use at all.
I'm not bad mouthing you if thats what you think.
these are Series 4000 MTU turbos. they look bigger I think. I'm going to do a couple 16v4000 startups tommorrow on frac units. I'll look closer.
