anyone in ponoka on here?
Old Nov 3, 2012 | 10:03 PM
kennyblatz's Avatar
i've been eyeing up this truck just wondering if anyone has seen it around, or if there is a ponoka member that can do a quick scan of the shape its in befor i drive down to look.
http://edmonton.kijiji.ca/c-cars-veh...AdIdZ418435395
thanks
Old Nov 4, 2012 | 07:18 PM
StealthDiesel's Avatar
That truck has a ton of mods. Proceed carefully...
It has dual CP3's, 90HP nozzles, but it looks like the BD Towing twins which are very small. That doesn't really add up and may be incorrect in the ad.
That truck should have the R700 or R850 BD Twins with that fuel.
It also doesn't make sense that he is running the entry level Edge Juice/Attitude with all those mods.
There are a ton of good aftermarket parts on that truck. Check carefully to see everything works.
Check blowby with the engine hot. I would also connect a mechanical oil pressure gauge to it to check hot idle oil pressure.
Also check for rust under the chrome wheel well trim.
Old Nov 4, 2012 | 07:45 PM
kennyblatz's Avatar
I will do that and look at it closely, i thought it was abit hi of fuel to air ratio but it sounds like he did tow so maybe he didnt want bigger twins because of that
Clane
Aug 5, 2009 06:19 PM
Luke S
Mar 19, 2003 08:47 PM
Dieseldude4x4
Dec 23, 2002 08:56 PM
Dieseldude4x4
Oct 17, 2002 04:58 PM
