Although the truck isn't running right now.......
I'm still giddy about the pulse monitor for the Adrenalin box which is on its way from Texas with a pillar mount.........[guitar] and all the other goodies I decided to do at the last minute [laugh]
I just really hope the bottom end holds together for a while after all this :o |
Originally Posted by 1-5-3-6-2-4
(Post 2002444)
That truck has transformed 100X since I saw it in Olds. Its really looking, and sounding sharp. You may need to girdle that block if you want to spool it up to 4K. Thats no small job either.
So the truck is running???Did the knock go away??
You might want to P Pump it next,, and really go after the hp. Unless you are running that weak block I think you should be ok with the stock block at 4k,, 5k, well that is another story
Kevin |
Work in Progress.........upgrade on failure.
I don't really want to P-pump it, I made the decision to stay electronic last year. I like this wizzy junk that you can do now for the vp truck with this big commander pod for the adrenaline and stuff like this push button programable stuff. I don't want all in p-pump power.......as in always on fuel. I want a really mean on demand daily driver. and I'll carry on the fight until I get there. |
