Air Bags
any auto parts store should be about to get they for ya. My local parts shops here in Airdrie have them. Get a kit with an air pump and remount dash controller. I have airbag kit in my 1/2ton, and its awesome. I just need heavy duty shocks for the front, now. Its as if dodge expects people not to use a truck as a truck. The air pump is also a nice back-up as well for very lite remote usage. Pumping up tires. You could put a air tank under the bed and run air tools.
I am looking for a set of them for my 05 now. I also have been looking at the front bags also that fit inside of the coils.
But to buy them up here they want a arm and a leg for them.
Around $500. Which is to much. if you guys know of any where cheaper let me know also.
When we drop this truck 3 inchs,I was thinking air bags in case I have to haul a heavy load...I was thinking to add the bags with the leafs...One thing that DOJ mentioned to me ,is once lowered,will a person be able to have enough clearence for air bags..So far I just need the bags and will fill maually.Maybe later if money premits,I may install a in cab compressor..
Yep...pulling the 5 inch block and putting in a 1.5 inch block.Thanks Tate....Never seen how these bags are installed...Without dropping the front end the difference is only 1/2 higher in the front compared to the back..Front will get lowered at a later date...
Hmmm...doing some research on the web on air bags....Some like them some hate them...Don't know about this one but one guy cracked his frame on his 95 ram....Anyone running rear airbags?How do you like them?Do they leak as bad as what guys are saying?
