***?? I'm getting pretty annoyed at this truck
on the new second gens ones they don't seen to . but on the the second gens they have that bypass hose ,
but the 1st gen has one in the stat and no bypass hose ....
I'm quite certain my cummins t stat has one. however i havent check the other t stat i have yet. either way, while this problem persists I.m gonna put a 3/16 to 1/4" hole in. I put my winter cover on the front for now and im gonnna see what temp that runs at. then try the t stat with hole. Time for some experimentation.
Should be two jiggle pins on the Cummins T -stat that was part of the TSB the cheap ones that dodge put in originally had one and then they TSB'ed it the second one I had, Had 2 jiggle pins I will see if I can dig up one of the old ones for the 2001
edit
https://www.dieseltruckresource.com/...t-t146039.html
edit
The Guru
Some cold winter days, I could idle my truck for lenghts of 1/2hr or more. Some days you need heat out in the field when you working and there are no warm buildings.
