Help me wire the 3rd brake light
2011 2500 Crew Cab Diesel, put my cap on today and got the dome light wired to the constant hot in the trailer light connector so that works good. The problem is the 3rd brake light can't be wired that way, you have left turn and right turn and no brake light wire, it uses the turns for the brake light, if you wire to one of those yea it works for the brake, but it also comes on with the turn signal. Someone mentioned there was a 3rd brake light wire in a wiring harness by the spare tire but I can't unwrap all those harness' to find it what a mess I'd make of that. So if someone has an answer or a solution I'd like to hear it, Thanks Mark.
What I did was wire to the left turn brake light. My reasoning is turning left if the top flashes so what it helps keep idiots from comming around me when I go left. I could not find just a brake light wire like you said
all of my dodge's have had a wire in the harness like mentioned above. I want to say it was white but don't remember for sure. They all had a little tag on them marked "CHMSL". They aren't long enough to reach all the way in to the cap wire.
jeff.
jeff.
anonymous_1
13
Apr 30, 2020 04:29 PM
Joey-D
Dec 12, 2011 12:52 PM
TPilaske
16
Nov 22, 2002 08:15 PM
