2013 fuel filter alert gauge
It probably works the same as the oil change interval, the truck knows whether it's idling or being driven at fast rpm so it knows how much fuel is passing through the filters, it's smart enough to give live fuel burn readings on evic and also keeps track of the drive and idling times.
Cummins Guru
I don't see why not I always do all the updates when doing the P26 update for the Anti-Lock Brake System Module Flash. There is usually a stored code in the PCM like U3017, the DCU (Dosing Control Unit) usually needs update as well.
I rarely tow so it might just be a default to change at 20k and if you tow more then it does a real measurement. I am shocked to hear this but that's pretty cool to know.
I'm not sure what the dam thing is reading. I changed my filters and reset the gauge. About 5000 miles later it said I needed to change fuel filtes so I just reset it and did not change now 10000 more miles and my gauge is at 15% so go figure!!!
spider_1954
09-05-2013 05:03 AM
smokinram99
12-16-2007 11:56 AM
Mopar1973man
44
07-02-2007 12:03 PM
PourinDiesel
12-20-2005 09:23 PM
