Which smarty?
Which smarty?
Just got back into the dodge cummins sickness, buying a 12 2500. I've been reading about deleting, the pros, and cons. I'm still confused on which smarty I need to buy in order to turn off the emissions garbage. I've seen the h s also, but thinking smarty is the way to go. Any advice would be appreciated.
Buying the Smarty will be more difficult as time goes on as the ME or delete programs are only loadable on the older versions that do not have a US serial number. The website states that those units will be locked out from loading ME/delete software.
Depending on what you want to tune, the Jr is a good value uploader. The Sr is for more adjustability if you are really set on that however, I don't think the SR is compatible with the 12's.
I've had Smarty, and h&s, just bought another h&s for our 12. The support is the best. Product is super easy to use, download to truck, and updates. Don't have to uninstall from truck to send to dealer, although recommended. Personally, I wouldnt touch Smarty. I trust h&s on a $60k+ truck.
iv got a 2010 dodge 2500 6 speed stick looking to do some up grades. I like the idea of the delete kit just don't now where to start don't have the money to do it all at once. can I get some input.
Funny over the years how opinions change. MADS used to be the only way to access the Cummins software and was making the replacement ECM's for the 98 and up 24V trucks with specific tunes. First to crack the bootloader software in 09. How times change I guess. H&S did better marketing.
2010dodge - Best bet is to read the sticky thread by Blake Clark on how to properly delete and that will fill in the holes for what you want to do.
Yeah Smarty used to be the way to go. I've heard support from them is just about not there. Its personal preference I guess. I would say if you only want to delete for mileage, just get the Jr if you get a Smarty.
Ive had no issues with my smarty jr on my 2010 great product.
http://smartyresource.net/forum/forum.php
This is a really fast way to get in touch with brian at smarty and I think marko to.
Sent from my SPH-L900 using Tapatalk 2
I have a 2011 6 sp with stealth deletes and smarty S67ME...ever since the deletes I have had a surge..after lots of research and finally Mads service center advised me they are having issues with the latest ME files causing the surge...they are updating a new version to correct the problem, but no idea when it will come out...it will not be available on their web site but it will be on the internet....the version should be "L" ....meanwhile my dodge bucks and the turbo isn't spooling correctly...can't go back to stock as I have the deletes done...so have to drive very sane in order to keep the surging down....Hope the new ME files come out soon, to tow with this is impossible...SO I am stuck for now.
Hope this helps you out.
stock03
04-02-2010 12:57 AM
sCreamin400
14
10-28-2009 05:46 PM
Bradleysram
19
05-12-2009 08:36 AM
UnrulyNFS
14
08-03-2007 11:13 PM
