2010 ramm 3500 o2 sensors
Ok so i have a 2010 dodge ram 3500 75000 miles Larmie
About a week ago my check engine light came on. So i took it to auto zone had them read the codes.
U011A. Lost communication eith exaust gas sensor module
P0037. Ho2s heater control circuit low (bank 1 sensor 2)
P113C. O2 sensor power supply circuit performance
P11C. O2 sensor power supy circuit performance
Ok so there are my codes. Im pretty sure its either my module or o2 sensor. I plan on doing my deletes on my truck egr dpf. So if i do will the deletes take care of this issue. I know the tooner has a reset for your codes because without it you would have light on any way because you remove alot on sensors. I only ask because if it will fix the issue i will be removing it vs fixing somthing i dont even want anyways.
nvr-enuf
04-22-2013 01:38 PM
imkman
29
07-28-2009 09:44 AM
